ls6 cam gains
Old 06-08-2008, 03:47 PM
180ls1's Avatar
Default ls6 cam gains
I search but i keep finding cars with ls6 intake, ls6 heads or ls6 blocks. So this is why i ask
How much with i gain with an ls6 cam on my 99 camaro with a cat back and fipk? I assume that there is not tune needed and i will see no surging or bucking wien i am down real low in the rpms because of its size. Charts would be very nice also.
edit:
the only reason i am considering this is because i think my oil pump is slowly going out so i would throw in the cam and springs at the same time as the pump and i am not sure i wan to to mess around with longtubes in california yet.
Old 06-08-2008, 04:54 PM
Magnet's Avatar
although you could probly get away with no tune, to optimize your gains and make sure there isn't any surging etc then a tune will help alot! as far as gains.. probly 20-30 rear wheel hp... maybe more with all the supporting mods and a spot on tune
Old 06-08-2008, 09:02 PM
180ls1's Avatar
ok thanks i will probably go with a street tune down the road, it is hard as hell reading all the posts that come up when i search "ls6 cam"
Old 06-09-2008, 02:38 AM
Magnet's Avatar
looking at your mods, i would do LT headers before a cam.. gonna be cheaper, net about the same HP if not more, and not mess up your tune as much..
Old 06-09-2008, 02:58 AM
bad95killer's Avatar
i would say 25-30rwhp but i would Get a custom grind camshaft then tune her on dyno to see more gains w/o any surging or bucking on low RPM just my .02
peace
Old 06-09-2008, 06:13 AM
james562's Avatar
15-20RWHP To get the most out of the swap I would have a local tuner bump the Limiter to 6200-6300 and shift around 6100-6200...
Buy some LT headers and an LS6 intake before you mess with a cam, your current plan would be doing it *** backwards...
Old 06-09-2008, 06:41 AM
LSWONGTO's Avatar
If I were you I would by some Longtubes like pacesetters with the ory for like 665 and a LS6 intake then do a cheater cam you would have stock driveabilty and it would be very reliable and make good sleeper power.
Old 06-09-2008, 11:33 AM
180ls1's Avatar
re edited the post i have a reason to the madness.
Old 06-09-2008, 11:39 AM
khaos288's Avatar
you're in cali....leave it stock, ls6 cam would probably exceed your emissions limit :-)
Old 06-09-2008, 11:51 AM
AU N EGL's Avatar
There are better cam then the LS6 cam.
LS-1 2001+ 198/208 500/500 116 lsa
LS-6 207/217 525/525 116
do something like a 224R or 228R
224/224 581/581 112 or 114
or
224/228 581/588 112 or 114
Old 06-09-2008, 12:51 PM
Kingc8r's Avatar
^ what he said. Sure the LS6 will show some gains, but I would rather spend my money on a cam that I could grow with if I were you
Old 06-09-2008, 03:15 PM
180ls1's Avatar
or
ya my biggest problem is living in california. I think i am just going to get the mti stealth 2 cam if i end up installing one, it should pass smog and drive nice since i will be drivimg my car 70 miles a day for the next two years.
Old 06-10-2008, 02:06 PM
180ls1's Avatar
I would love to see a dyno graph
