tsp built 408 dyno #'s?
Old 06-16-2008, 11:36 AM
william's SS's Avatar
Default tsp built 408 dyno #'s?
I'm getting a 6.0 408 lQ9 assembled short block built by TSP for my 2001 SS. Cam is comp cam custom 240/244 609/612 114 lsa, heads are TFS 235 milled to 62cc making 11.2:1 CR, Fast 92/92 ported tb and intake/fast fuel rails, racetronics fuel pump, ls6 oil pump, asp underdrive pully, 36 lb fast injectors,slp maf, lt 1.78 headers /y-pipe borla catback, ls2 timing chain. Performabuilt level 2 trans with vig 3400 stall. And moser 9" 3.89. So what should I expect with a good tune on dynojet? My goal is 500rwhp or more is this feasible with my set up?
Old 06-16-2008, 12:25 PM
1ORANGEWS6's Avatar
Do you plan to spray it later?
Old 06-16-2008, 12:38 PM
Yes definitely. Im thinking anywhere between a 150 shot to a 250 shot (max) but that wont be 4 a couple more months.
Old 06-16-2008, 01:39 PM
1ORANGEWS6's Avatar
Well you may not see 500 NA but I think you should be close. I know you will for sure with a little spray. You might want to also look at a backup plan on the ole 4L60 and look at getting an additional fuel pump or a stand alone for the spray. My tranny has less than 2000 miles on it and I don't want to ruin it behind my 408 and spray. I would rather sell it and get a 4L80.
Old 06-16-2008, 01:46 PM
02HawkTA#195's Avatar
i would go bigger than 36 lb injectors. if your already in there anyways u might as well. i made the mistake cuz i wasnt plannin on spray till after i got halfway through the project
Old 06-16-2008, 07:24 PM
Kingc8r's Avatar
Good advice...4l80 isn't a bad idea either....
Old 06-16-2008, 08:09 PM
slow trap's Avatar
i'd say with an m6 that setup should be good for 530-540 so with the vert locked it should be in the 490-500 range just guessing.
Old 06-16-2008, 08:34 PM
Default cam?
Do my cam specs look right , Im looking for the best cam for lowest et
Old 06-16-2008, 08:54 PM
beardWS6's Avatar
Good set-up. I have a 408 with A4 and love it. I got numbers in my sig. I have alot bigger cam than yours. Mine is 250 255 640 640 113 Our A4 are hard to pull good numbers on the dyno. They show at the track!! But you have a strong set-up. I also spray a 200 shot and its awsome. I have 42lb inject, fuel rails, 255 in-tank pump for the spray-wet kit! as for the tranny being a concern. Century built mine tough, haven`t had any issues at all! I have a stage 3 build. Thats what you need also for future spray, Let me know if you have any questions. My set-up is very close to yours!! Good Luck!!
Old 06-20-2008, 01:12 AM
MASS seller approved
smok'nZ's Avatar
get rid of the slp maf seen alot of people to lose power with them
Old 06-20-2008, 06:45 AM
LS1Tech Sponsor
Slowhawk's Avatar
The tranny won't last long but you should be at 500rwhp with it locked. I like that cam on a 112 with 4 degree's advance.
Old 06-21-2008, 05:04 PM
What would a good choice for a maf.
Old 06-21-2008, 09:00 PM
89Formulaws6's Avatar
i went with a stock z06 85mm
Old 06-21-2008, 11:51 PM
smok'nZ's Avatar
i have a delphi 85mm
Old 06-22-2008, 08:29 AM
beardWS6's Avatar
I went with a SD tune and don`t have one!!
Old 06-22-2008, 11:27 AM
how much better is going to sd like driveability wise? whats the pros of even going for it
Old 06-22-2008, 01:58 PM
beardWS6's Avatar
Drivability is awsome going from a standard tune to SD tune. My cam is so big that it surged when driving alittle and cold starts where tough. Now I can start right up and back out of the garage to let her warm up and drivability down low is sweet! I let my wife drive her now!
No MAF is needed with SD tune.
Old 06-22-2008, 03:51 PM
cool thanks my ex tuner said sd was pointless
i got some surging at 1/8th throttle and some at 1/4 even at 1600rpms
Old 06-22-2008, 04:57 PM
smok'nZ's Avatar
a big cam will help you reach your 500 mark
Quick Reply: tsp built 408 dyno #'s?
