98 SS cam only dyno results
Old 07-04-2008, 01:37 AM
torquejunky's Avatar
Default 98 SS cam only dyno results
Let me know weather or not you can view the vid, this is my first one of this length and I'm unsure weather the codec I used will be viewable by all.
Here's the video:
98 Camaro SS Dyno Run
Here's the graph:
Old 07-04-2008, 02:07 AM
98camaroLS1M6's Avatar
LS1 intake? Looks like a lot more left in it with a good intake. Nice torque down low!
Old 07-07-2008, 02:56 PM
mrr23's Avatar
yes, he has a LS1 intake on the car.
Old 07-07-2008, 04:15 PM
Evans752's Avatar
Congadulations very nice numbers for the setup so far, real nice looking car and clean from what I can tell on your video. Good Luck with it and be safe.
Old 07-13-2008, 12:16 AM
twitchtwice's Avatar
i bet with an ls6 intake he'd be looking at about 370-380
would be money well spent.
Old 07-13-2008, 05:58 PM
Yep LS6 intake and the NX wet kit that's been sitting around for a while are next on the list. I've only had this car for about 5 months and I came across a good deal on the cam so I did that first.
Old 07-25-2008, 01:41 AM
ls1chris's Avatar
damn close numbers to mine,we have basically the same set up
i have 232-234 cam ,lt's,xpipe, Lid and the BBk ssi intake,4.10's and in humid muggy weather i put down 368-351.
im looking at swapping my intake out to the ls6 and shoot for 380+ also
Old 07-25-2008, 10:57 AM
tnmotown's Avatar
not bad! but like others said, LS6 intake, pulley and p&p throttle body you should be 380+ with no problem
Old 07-25-2008, 12:46 PM
registered user
ScreaminRedZ's Avatar
Nice curves. If you finish off the bolt-ons I bet you could hit 390ish rwhp!
