Whats the powerloss for...
I pulled a 376RWHP/370RWTQ on a dyno jet sae corrected.
Mods are in sig, but i wanted to know the power loss of the 12 bolt with 3.73's w/ a LS7 Clutch. Compared to the stockers. Thanks for the help.
My friend with a similar setup to yours, except with the VRX4 and a ported Fast 92 mm intake made around 384 to the wheels SAE corrected on a dynojet. Seems like you're making right around where you should be especially considering that his cam is slightly larger.
O i see.. given the same dyno in the same conditions i would expect around 15-20 more. You would be right around the 400 mark. I wouldnt get to wrapped up in the numbers though man, i would take the lil bit of power loss to launch at the track anyday.
