LQ9 under the knife soon - LS1TECH
Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
Thread Tools Search this Thread
Old 08-27-2009, 07:29 PM   #1
Default LQ9 under the knife soon
Alright people, car is going in tomorrow to get my LQ9 put in.
Stock 6.0 liter cubes
Stock 317 heads
Predator Z cam 230/228 .592/.588 110-1 LSA (9 degrees of overlap )
Lid
1 3/4 stainless headers
TSP true duals (sweet thunders)
3600 edge racing stall (4L60E)
LS6 intake manifold
Random free mod here and there.
What am I putting down? With my boltons and this same stall, it did 330 hp 340 tq in 95 degree weather in the shade.
If you get it right, I will paypal you $1
Gaunt is offline   Reply With Quote
Old 08-28-2009, 07:30 PM   #2
No guess, even for a dollar?
Old 08-29-2009, 05:40 PM   #3
RaggedRides's Avatar
Definitely stronger than an LS1, especially considering the torque and fact that it still made those numbers through a stall. I got no idea what it'll make, but keep us posted. After I get my money under control, I'll be slowly going your route.
Why the choice to stick with 317s? Budget?
RaggedRides is offline   Reply With Quote
Old 08-29-2009, 07:11 PM   #4
jetlag's Avatar
If I win, I'm going to need $1.03 to cover paypal fees.
jetlag is offline   Reply With Quote
Old 08-30-2009, 02:06 PM   #5
Budget yes as far as the 317s go, and I'm not entirely sure on which direction I want to go for future power actually...
Everyday it changes between forced induction and a crazy *** NA build... So it would a shame if I spent the $2k on a nice set of heads and regret it.
And jetlag,
Paypal fee will be accounted for
Old 08-30-2009, 02:34 PM   #6
WYATT318MOPAR's Avatar
Quote:
Originally Posted by jetlag View Post
378/381
I can't see it going that high with really just a cam and headers on stock compression. The stall will eat up some anyways so I am leaning more toward 350hp/362tq. You should have a little room for milling, then if you decided to go boosted later just add back the room for lower compression with thicker gaskets.
WYATT318MOPAR is offline   Reply With Quote
Old 08-30-2009, 04:27 PM   #7
NemeSS's Avatar
whats wrong with 317 heads? they are basically the same thing a s 243 799 head but with larger chamber. the 243 and 799 have the benefit of acheiving higher scr. other than that. same thing.
in a 370ci .030 over lq4 i put togther with stock milled 317 heads, lpe gt11 cam, full bolt ons and makes 416rw thru stalled 60e. cam is less than 220 duration on intake
NemeSS is offline   Reply With Quote
Old 08-30-2009, 04:31 PM   #8
NemeSS's Avatar
Quote:
stock lq9 is 10:1 stock, so if he mills and uses thinner gasket such as ls9 it will significantly raise the scr and improve the quench area. its possible to achieve up to 10.6:1 with milled 317 and thin gasket.
although if he does that, then has to account for ptv and will have to machine in relieves to the pistons for correct install.
Old 08-30-2009, 07:58 PM   #9
Oh yeah, I have thought about that for sure, but it really isn't fitting into my Summer budget, otherwise I would have done something along those lines.
However, I have no desire to worry about PTV clearance so that removed it from the equation as well.
I think my power goals would be out of reach from a set of 317s if I was to do something NA build related, but boost related, I know they could get the job done (Obviously it has been done many times in the forced induction section).
WYATT318MOPAR- I'm genuinely interested for your reasoning on such a little leap in power. It looks like you have a 6.0 from your sig, so that's why I ask. I mean, I don't put too much effort it trying to achieve dyno numbers for number contests, but keeping same compression, bumping up the cubes and adding a mild/medium cam only would give me 20 hp/tq?
Old 08-30-2009, 08:28 PM   #10
Your only gaining like what 15 cubic inches and a mild cam. I know my car is a different animal all together because my tranny cannot be locked during a pull with it being a 400th. My engine is also pushing 11.6:1 and only puts down 374hp at the wheels. I just don't see you gaining that much with so little changing and no leap in compression that is what really wakes these 6.0's up. I am also maxing out the current set of 28.8 injectors in the car "36's on the way" which is normally something that happens in the 420-430 rwhp range. Don't get me wrong it will be a torque motor and probably a blast to drive. I am actually looking forward to see what it does put down just to see if I am close. I don't know what you were really shooting for as you keep talking about going forced induction.
Old 08-30-2009, 08:52 PM   #11
Yeah, this setup is something to hold me over for the interim while I get something more concrete as a route for power. I know that I'm turning it into a 408. I am considering either doing a d1sc setup after, or a significantly worked L92 headed higher compression motor. Both radically different from
one another, but they will achieve what I want. I want to drive in both before I decide.
I would be more than ok if it dynoed a number like that, but doesn't everyone hope theirs are just a little extra kind of in that hopeless optimism boat right now lol :/ realism wouldn't hurt though.
Old 08-30-2009, 08:59 PM   #12
I have been hard shopping on some L92's but the intake choices really suck in my opinion don't really want to even think about a L76, I hate Fast and would never pay that much for an intake that was plastic, leaning towards either a sheet metal or something along the single plain line if I can find such a thing. My top end is really holding me back right now I feel like the LS6 is choking my motor on the big end but based of intake pressures on the dyno the tuner says no. Told me the other day that a fast 90 setup would probably only net another 20rwhp that is a lot of cash for a little gain in my opinion. The car runs great I keep changing things so haven't really got to the track all year went to a little 300 ft track last week and got rained out shooting for low 4's on motor.
Old 08-30-2009, 10:06 PM   #13
Yeah, I have people that say the LS6 intakes don't get enough credit, and those that say switch it for a FAST asap. Ported LS3 intake was the intake I was assuming for the L92s however, but I'm not sure how expensive that was in relation to the FAST (or performance for that matter)
Old 09-01-2009, 12:15 AM   #14
AznMuscle's Avatar
360/370. If I win...just give me that **** sometime lol. And only 9* overlap? Step up your game lol.
AznMuscle is offline   Reply With Quote
Old 09-01-2009, 01:28 AM   #15
Quote:
Haha, if you win, I can hand over the winnings in person
My game can't step up any higher right now It's my DD to Tempe
Old 09-01-2009, 01:50 AM   #16
AznMuscle's Avatar
My DD has 23* overlap . Only 242/248 duration as well.
Old 09-01-2009, 12:52 PM   #17
Damn you Stealing all my thread thunder with your nonsense! In other news, if you ever feel the urge to go to firebird in the coming months, let me know.
Old 09-01-2009, 01:14 PM   #18
AznMuscle's Avatar
Hopefully I can get my 16s from back home, and throw some DRs on it, and I'll be down. 1st is useless on the street, let alone at Fireslick. I want to make it out to SW one day...but **** that is a drive for us. Will your car be done by Thursday?
Old 09-01-2009, 01:17 PM   #19
Ahh, probably not done by thursday. Optimistically, I'm looking at the car being done Friday night/ Saturday morning, then tuning immediately after. Still need to sort out finding a set of M/Ts.
I don't think Nittos are going to cut it for me and my stall anymore :/
Oh also, firebird has decent track prep, but I've always heard SW was the worse of the two (I haven't been to SW, so I can't comment too much on it... and I refuse to drive up there regardless).
Old 09-01-2009, 03:29 PM   #20
AznMuscle's Avatar
I hear SW is better then Firebird. Either way....both beat the **** out of SIR.
Related Topics
Thread Thread Starter Forum Replies Last Post
Yet Another Speculative Cam Thread...Come Chime In! MaroonMonsterLS1 Generation III Internal Engine 7 07-05-2016 11:48 AM
LQ4 799 heads or cometic gasket 317s to raise compression scidav87 Generation III Internal Engine 5 03-13-2016 04:50 PM
lq9, 6.0L lsx questions sc6speed Generation III Internal Engine 5 01-17-2012 04:51 PM
LQ9 Build, what am I looking at? sman Dynamometer Results & Comparisons 4 02-24-2011 12:57 PM
Cam only LQ9/LQ4 Numbers redt/a2000 Dynamometer Results & Comparisons 11 09-17-2009 10:10 PM
Tags
030, cubic, gas, lq9, mileage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
