What should she run?? - LS1TECH
Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
Thread Tools Search this Thread
Old 12-05-2011, 01:20 PM   #1
Transam1's Avatar
Default What should she run??
i run 1/8 mile but 1/4 guess are fine
99 T/A with zero weight reduction other than no front swaybar
347ci ls1 out of 02 camaro
afr225's @59cc
236/242 .615/.615 111 LSA Raptr cam
1-3/4 headers w/ cutout
UD pulley
36# injectors w/ fuelpump
LS6 intake and stock TB
edge 5000 converter, shift kit, etc...but not built just freshened up
3.42 rear 10bolt w/ nitto drag radials 12" wide (i think this is most of my problem) 17" TT2's
LCA's, Subframes and i guess that's about it
ide like to know what i should run because my best is 7.70 @ 91.25mph w/1.70 60' that lifted the front left about an inch! haha so the spectators say anyways.
Transam1 is offline   Reply With Quote
Old 12-06-2011, 07:25 AM   #2
blk/slvr02ss's Avatar
11.40@116 W/ a good 60 ft !!!
blk/slvr02ss is offline   Reply With Quote
Old 12-06-2011, 07:55 AM   #3
Transam1's Avatar
so whats holding me back from a 10sec car? intake and bigger headers? compression is a little more then 11:1
Old 12-06-2011, 09:17 AM   #4
1 7/8 Headers,Fast Intake & TB and u should b there !!!What do u have for suspension and weight reduction ?
Old 12-06-2011, 10:42 AM   #5
odarabla's Avatar
You can run high 10's with your setup. My old setup stock bottom end H/C/I LS1 went 10.90@123mph full weight and stock suspension.. Like said before get rid of the LS6 intake and TB..
Good luck on your quest for 10's buddy..
odarabla is offline   Reply With Quote
Old 12-06-2011, 06:35 PM   #6
Transam1's Avatar
pretty much stock suspension, no weight reduction, might take the AC off since it doesnt work anyways. stock front shocks w/117k on them and monroe(replacement shock) on the back a 2years old.
Old 12-11-2011, 05:08 PM   #7
Transam1's Avatar
any other opinions?
Old 01-16-2012, 05:03 PM   #8
Too much head IMO.
89pigeontoe is offline   Reply With Quote
Old 01-16-2012, 05:59 PM   #9
1Bad97WS-6's Avatar
I'm gonna say it should run 7.3s-7.4s in the 1/8th
1Bad97WS-6 is offline   Reply With Quote
Old 01-17-2012, 10:28 PM   #10
I am also thinking 730's - 740's , However 5000 stall seems a little high , your probly wasting some power with that converter . and those TT2's are not helping either . my car picked up a honest 2 tenths going from ZR1's to Weld rodlites with the 15x8 / 15x4 combo . Like others have said those are some big heads for a 347 , the LS6 intake is great for a mild combo , but your car with those heads is in need of a FAST 90/90 ! If you can change a few things and get your combo working together low 7's are in the future.....
Scooter76 is offline   Reply With Quote
Old 01-17-2012, 10:30 PM   #11
JUSTINSWS6's Avatar
That rear isnt going to hold.
JUSTINSWS6 is offline   Reply With Quote
Old 01-18-2012, 07:20 AM   #12
Transam1's Avatar
looks like i will be moving towards a rear-end first, hopefully shortened 2" a side, then the drag wheels, then the intake and other stuff.... like some have said, with a sticky tire that rear is going to snap!
Too much head? they are the small bore 225's and in the sticky "quest for 500hp" mamo/pat g or whoever posted that switched out the aft205's for 225's and it helped a bit
Old 01-18-2012, 08:02 AM   #13
Captain Double Post
Quote:
Too much head IMO.
lol ok man, honest man a drag wheel setup will help, and im sure swapin gears would help alot,
BOBS99SS is offline   Reply With Quote
Old 01-18-2012, 08:04 AM   #14
Captain Double Post
i have seen lots of ten second ten bolt auto cars, depends on the setup but ten bolts last alot longer in a auto then a m6 car, op what is your exhaust setup?
Old 01-18-2012, 08:07 AM   #15
Captain Double Post
1 7/8 headers and a good dual exhaust set up will help alot, fast setup would help,weight and suspension honest op there is alot left in that setup, how well does the car hook?
Old 01-18-2012, 08:00 PM   #16
Transam1's Avatar
exhaust is 3"Y after headers followed by a 3" cutout, does not hook very well on the 315 nittos, spins a good 50-70ft...by spin i mean not fishtailing but not a dead hook for sure. im sure a 3.90 or 4.10 gear would help (if it hooked) but waiting on that to go in a stronger rear. the cam suggests 4.10's and 4k converter. i am yet to dyno tune but cam should start making power around 36-3800 and since the heads are a little big i would assume it would kick in around 4000+
also all runs have been with spare tire and all in the back, not that it will make that much of a difference...i dont think
Related Topics
Thread Thread Starter Forum Replies Last Post
Can i break 500rwhp with this setup? nickp0808 Dynamometer Results & Comparisons 19 04-04-2016 12:38 PM
What's considered "high lift" on a blower cam these days? turbotuner20v Forced Induction 10 07-02-2015 09:04 AM
H/C Thunder Racing Combo, any guesses? Transam1 Dyno Guesses & Bench Racing Forum 4 11-12-2011 08:58 AM
408 gas mileage? Hmm. 408LS1TA Generation III Internal Engine 6 11-30-2005 03:24 PM
Tags
18, 73s, 99, full, mile, opinions, rodlites, run, weight, weld, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
