5.3 h/c/i/e - LS1TECH
Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
5.3 h/c/i/e
Thread Tools Search this Thread
Old 05-09-2012, 12:41 PM   #1
milktasd's Avatar
Default 5.3 h/c/i/e
Building a 5.3 for my 00 Sonoma and finally got all the pieces for my motor in.
5.3 with new rings and bearings
Ported, polished, valve job, bowl job, milled 30 243s
Ls6 intake
85mm maf
Ls1 tb
Ls6 injectors
Spectre cold air intake
Brp longtube headers 1 3/4"
Eps 218/226 .595 .598 112+3
All going through a t56 and a 4.10 gear 7.5" rear on stock wheels and tires. Hope to have the motor in next month and be able to drive it by July. Will be going to eps for a dyno tune. Just curious what everybody thinks it will make.
milktasd is offline   Reply With Quote
Old 05-09-2012, 09:20 PM   #2
Grumpy Bastard
Gunslinger09's Avatar
Ls6 intake
85mm maf
Ls1 tb
Ls6 injectors
I think you will hit 395HP.
Gunslinger09 is offline   Reply With Quote
Old 05-10-2012, 05:25 AM   #3
milktasd's Avatar
Hope so. That is what my friend and I think it will make too or around there. Would love to see 400, but won't complain if it's less.
Old 05-10-2012, 08:48 PM   #4
I'll be watching this thread because I am considering going the 5.3L route later.
carguy_24 is offline   Reply With Quote
Old 08-16-2012, 11:32 AM   #5
milktasd's Avatar
Just an update with more parts:
Added a ported throttlebody and depending on room for exhaust 3" duals with x pipe or 3" y pipe with magnaflow catback. Will also have cutouts. Hoping to be on the dyno by the end of the month.
Old 09-28-2012, 06:57 AM   #6
milktasd's Avatar
Headed to eps tomorrow for dyno and tuning.
The exhaust is 3" mandrel bent through dual in single out magnaflow muffler and also added an under drive crank pulley. Truck feels strong. Pulls hard to 6500, might end up raising the rev limiter because it doesn't stop pulling. I'm happy with the butt dyno can't wait to see what the actual numbers are. Here is the idle clip http://youtu.be/bym4z5bO_uw
Old 09-28-2012, 09:39 AM   #7
milktasd's Avatar
2000 Sonoma 5.3/t56
Ported, polished, milled 243s
Ls6 intake and injectors
Ported tb
85mm maf
Cold air kit
Under drive pulley
160 thermostat
3" mandrel bent exhaust dual in single magnaflow with dual cutouts
4.10s stock rear with stock size tires
Old 10-02-2012, 07:55 PM   #8
Still watching this thread and your truck sounds nice. I'll be keeping an eye out to see your dyno numbers after you get the tune.
Old 10-02-2012, 08:31 PM   #9
milktasd's Avatar
Made 340 rwhp with the cutout closed and 370 rwhp with the cutouts open.
Cutouts closed
http://youtu.be/1ZMswV8lMQo
Cutouts open
http://youtu.be/zDidm-N233Y
Related Topics
Thread Thread Starter Forum Replies Last Post
Thoughts and input on 5.3 build for Jeep Mud/Crawler grantpo Generation III Internal Engine 2 12-21-2015 12:53 PM
LS3 intakes, which one? Zfan Generation IV External Engine 8 10-11-2015 07:41 AM
New setup 408 with 243's Brennen's01SS Dyno Guesses & Bench Racing Forum 16 04-27-2012 08:09 PM
eps cam hsvgtsr Generation III Internal Engine 25 12-30-2011 01:41 PM
Tags
2011, 218226, 53, 53l, 595, 598, cold, dyno, eps, hc, hci, ihe, ls1, recommended, rpm, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
