Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
Turbo LS1 dyno estimate...
Old 05-21-2012, 09:48 PM
jt76's Avatar
Default Turbo LS1 dyno estimate...
Figured i would get a feeler for what to expect..
2000 Trans am, 6 speed, 9 inch
forged 370 CID
stock 317 heads (dual springs etc)
speed inc tu2 cam
LS6 intake/ ported TB
Dual pumps with -8 feed/ -6 return and 80lb injectors
Precision PT76GTS turbo
Kentucky turbo front mount
FMIC setup
dumped downpipe
My waste gate spring is 11 psi, i plan on turning it up to 15-17 psi
whattya' think?
Old 05-21-2012, 11:42 PM
ZTwentyAteU's Avatar
mid 600s-700 wheel. Depends on timing/air. What does a PT76GTS run out of steam at? Is that billet wheel?
we did my buddies 370, "boost cam", stock headed, s475 a2w setup a couple months ago. Made 710RWHP on 13psi. This is through a locked 4l80 and dana60 rear with 3.73 gear. It will make 709-710 pull after pull.
I think the s475 with cast wheel is close to running out of steam on us though
Old 05-21-2012, 11:52 PM
Gunslinger09's Avatar
Im going to say 695 HP. The 9 inch will eat up some power.
Old 05-21-2012, 11:58 PM
smokeshow's Avatar
My 4.8 makes 650 on 17psi through an 80e lol. A 370 ought to see 800s with that turbo at 17psi, otherwise your tuner is doing something wrong. That's assuming you have good fuel...
Quick Reply: Turbo LS1 dyno estimate...
