Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
What sort of ET and MPH would you guess
Old 09-09-2015, 11:48 AM
Lawhead's Avatar
Default What sort of ET and MPH would you guess
With my build getting closer and closer to being complete I'm getting antsy and bored over here in Europe while I collect parts run down is
Engine
370 CI LQ4
14:1
E85
ARP Main Studs
ARP Head Studs
Wiesco 12CC Dome Pistons with Total seal rings
Scat 6.125 H-beam rod ARP 2000's
Stock crank polished and turned
CNC'd LS3 Casting (Flow 378CFM at 4.030)
Ported Super Victor EFI also ported
.040 Cometic Head gaskets
4150 TB
80LB injectors
TSP 2 inch primary header 3 1/2 collector
251/271 .700/.680 113 LSA Low Lash Solid roller Spec by Martin@Tick
Lunati Solid roller lifters
Jesel Shaft mount rockers
ATI Balancer
Holley HP
This will be going into a 00 Z28 hard top in front of a Glide with a 12 bolt being N/A I opted for the glide and 12 bolt to reduce the power it takes to get the drive train in motion, every little bit counts
Plans for the car are 2800 race weight with 4.10s on a 26 inch tire or 4.56s on a 28 inch tire with a stall in the 6000 range. Soft goal is to go 9.99 N/A not sure how deep into the 9s I can get but what do you guys think ? Just bullshitting here in Germany bored looking for some discussion material !!
Old 09-10-2015, 07:00 AM
Lawhead's Avatar
No one want to hurt my feelings? Lol
Quick Reply: What sort of ET and MPH would you guess
