Daily Driver Max Effort Build
Heres the Combo: Guesses?
2002 WS6 M6 60k 346ci stock bottom end
-CNC 243s Milled .030 perf.valve job 11.1 compression
-Ported Peak Speed Fast 92/92
-TR 224/227 .563/.569 114LSA
-Kooks 1 3/4 heads w/hi flow cats
-MagnaFlow Catback
-SLP LID
-85MM MAF
-Fast 36lb injectors
-Fidanza aluminum flywheel
-Rockland Sons of Tranzilla T56
-Chrome molly shaft
-Moser 12bolt w/3.42 Trutrac
-MagnaFlow Catback
-SLP LID
-85MM MAF
-Chrome molly shaft
Thinking a little bit more. I see Bolt on 224/224 cars making 390-400 rwhp. The 243 head itself is worth a few and these are cncd ported and milled to a 59cc chamber. Then theres the PORTed fast 92/92. All of this threw an M6 tranny with a ligntweight drivetrain (minus the 12 bolt). Anymore dynojet guesses?
Been there, done that with my 396 Lt1 with 248/254 duration cam. Bigger cam isnt always what makes power and at the sacrifice of drivabilty and power under the curve. You can make great power with a mid lift 220s cam but you need an efficient intake in front of a set of really good heads. Ive been sandbagging here just to see what other people think but im confident i will be in the 430-460 mark with this setup.
Location: Coast of San Mateo County Between Pacifica & HMB
425 RWHP Tops.
Smallish Cam, small headers, (dual exhaust or y), small intake.
227/231 .600"/.580",1 7/8" LTs, (true Duals) Ported FAST 102
90/92 TB w/ velocity ring, ~ 440-450 presuming excellently
Ported 243s.
My .02.
Should still be a Great DD with excellent throttle response.
When will this be on the Dyno?
Ported 243s.
My .02.
425 RWHP Tops.
Ported 243s.
My .02.
Ported 243s.
My .02.
Well finally got the car dynoed. I was very pleased with the results.
428RWHP/397RWTQ SAE
438RHWP/405RWTQ STD
Remember this is through a 12 bolt rear end with 1 3/4 headers and magnaflow catted exhaust. If you look at the graph you can see where it picked up significant torque in the midrange, actually 22 ft pnds at one spot. A/F was pretty much 12.8 all the way through. Tried many variations and it seemed to like that AFR the best. I started the timing low at 22 and added 2 degrees at a time. Finally ended up at 26 degrees and thats where it liked it. Overall, im happy. Its the perfect amount of power for a daily driver. If i want more i,ll add a D1SC. Nitrous is $6 a pound up here in mass for you wondering.
428RWHP/397RWTQ SAE
438RHWP/405RWTQ STD
428RWHP/397RWTQ SAE
438RHWP/405RWTQ STD
428RWHP/397RWTQ SAE
438RHWP/405RWTQ STD
