Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
Iron 347 H/C/I Guesses?
Old 04-29-2016, 11:25 PM
89Mongoose's Avatar
Default Iron 347 H/C/I Guesses?
I'm trying to be more active in the forums, so why not see what people think and discuss.
Iron 5.3- 3.905 Bore x 3.622 Stroke A.I. 226cc 243's-BTR Platinum Springs/ Milled down to 59cc/11.4:1 Static CR
Wiseco -3.2cc Flat Top w/valve reliefs
Callies Compstar 6.125 Rod/ARP 2000
232/234 .600/.600 tspTorquer v2
Fast 102/92 with 42lb Injectors
Stainless Works 1 7/8 Headers
T56-MGW shifter and stage 2 Monster/18 lb flywheel
Build is going into a 3100 pound car 3.90 Gear
What do you think itll do in the quarter or make on the dyno? 89 Firebird Formula.
Old 04-30-2016, 06:14 AM
1997trans-am's Avatar
cam specs?
I imagine you would crack 430whp, depending on how high you want to spin it.
Old 04-30-2016, 10:39 AM
89Mongoose's Avatar
Oops forgot that, edited, Texas Speed Torquer V2
Old 05-02-2016, 07:02 AM
89Mongoose's Avatar
Anyone else?
Old 05-02-2016, 09:05 AM
Dimeomboost's Avatar
Originally Posted by 89Mongoose
Anyone else?
A friend has nearly identical setup except for he has a ls6 intake and stage 2 243s but he made 433 whp on the dyno we only have 1/8 mile tracks around here with a 3160# s10 3.27 gear he ran 6.5x in the 1/8 but we have lots of suspension issues were trying to work out also
Old 05-02-2016, 06:16 PM
89Mongoose's Avatar
Man, the truck should be good enough for 11s sounds like.
Old 05-05-2016, 10:00 PM
89Mongoose's Avatar
Any guesses on track times with my set up on a DR?
Old 05-10-2016, 12:12 PM
SteenH's Avatar
Friends setup (1998 z28)
SBE ls1, 59cc PRC 2.5 5.3 heads(right around 11.4-1)
torquer V2(112) ls6 intake, ported TB, 18lb flywheel, monster STG3
Through the M6 and 10 bolt on what I believe is a happy Mustang dyno it made 460RWHP/430tq. spinning it to 6500
runs very strong, 20 year old kid beating all of the older guys around town.
Car is 4.30 gear/s60 now, track times soon.
Old 05-10-2016, 03:05 PM
camarof41_383's Avatar
I have a similar combination in a 91 Camaro.
LS1 stock bottom end
AI 226cc 243's with BTR springs, milled to 62cc
228/232, .625/.625 112lsa AI custom cam
Fast 92
NW 92 throttle body
Fast 36lb injectors
Stainless works 1 3/4 headers into 3.5in mufflex cat back
4l60e with FTI 3200 stall converter
12 bolt with 3.42 gears
Mine made 434rwhp, 398ft/lbs on a dyno jet. In theory your car should put down a little more with the higher efficiency of a t56, more compression, Fast 102 and 1 7/8 headers but all dynos are different. Don't get too hung up on dyno numbers, the mph at the track will tell the real story of how much power it's making.
I would guess your combination should put down about 450-460rwhp on a dynojet and mid to low 11's depending on how well the suspension works in the car. If the suspension is really dialed in a high 10 should be possible in a car that light.
Keep us posted on the results! I'm anxious to see how your combo does on the dyno and at the track.
Old 05-11-2016, 12:08 PM
89Mongoose's Avatar
Sweet, this is probably the closest build to mine. If im hitting a solid 11 sec quarter mile i'll be happy. I'll post an update once it's in soon. Just bought the UMI k-member for it all and MgW shifter.
Quick Reply: Iron 347 H/C/I Guesses?
