Turbo!!!!!!!!!!!!!!!!!
Stock 06 GTO 6.0L edelbrock intake custom front mount T76mm turbo, ONLY 7PSI and 21,xxx on the motor, no cam, no heads!!!
Pics...
And the Dyno Vid!!!
http://www.youtube.com/watch?v=n2zfqZ9W5CQ
NUMBERS!!!!
532 RWHP
517 RWTQ
Pics...
And the Dyno Vid!!!
NUMBERS!!!!
532 RWHP
517 RWTQ
That's a lot of exclamation marks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Andy, help me out with the numbers some, not all too sure about the 6.0 liter in the GTO. I thought the 6.0 liter was the LS2 with 10.9:1 compression? I just like to see the numbers a bit higher with a boosted car with more compression. And considering no parisitic loss with the turbo vs. supercharger figured may be a bit higher also? But I dont much about turbos other than in a manual configuration they suck...
Originally Posted by TempleU_WS6
Awesome!!
Cant wait to be FI too! Shooting for next month.
Those numbers sound really good to me for only 7psi. He is really far down in the compressor map on that 76mm at 7psi. You might be surprised how much it will pick up if you push it up around 12psi with some meth. I'm not saying its a huge turbo but it will get more effecient as the pressure ratio goes up into the sweet spot.
My truck with the t76 and stock lq4 picked up 200rwhp going from 8psi to 13psi.
