Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
82mm turbo or ysi or f1c?
Old 09-21-2011, 03:43 AM
scottywheels's Avatar
Default 82mm turbo or ysi or f1c?
Help me make a decision because there r pros and cons to each
Old 09-21-2011, 08:22 AM
ls1curt's Avatar
Turbo
Old 09-21-2011, 08:25 AM
LS1Tech Sponsor
Slowhawk's Avatar
A correctly built Turbo kit will be the fastest and probly the best driver.
Old 09-21-2011, 08:34 AM
Devilish34's Avatar
key word
is that a stock 6l80eboom trans in the car?
Old 09-21-2011, 10:27 AM
Moderator
thechef's Avatar
id say go with the blower as they have full kits ready to put on the car, and that turbo kits can make the big power but there are way to many "turbo builders" out there that for some reason always fall short of getting the jobs done correctly or even at all.
Old 09-21-2011, 12:34 PM
LS1LT1's Avatar
Originally Posted by ls1curt
Turbo
Originally Posted by Devilish34
key word
Yeah, that would be my main concern even with just the heads & cam in the car now.
It's a GREAT trans but it does not get along well with 800+rwhp in a 4000+ pound car.
Old 09-21-2011, 01:31 PM
key word
I am not worried about the trans. My oy jamie runs the tranny tuned correctly and has 200 passes on it running 10.20's with a root blower.
The turbo look fun and I know someone that can build it correctly, its just watching that YSI can only car this weekend go 9.82 was awesome..lol
Old 09-21-2011, 01:54 PM
Moderator
thechef's Avatar
go with whatever can be ready to race by spring!!!
Old 09-21-2011, 02:10 PM
LS1Tech Sponsor
Slowhawk's Avatar
The 6L80 tranny just sucks ***.The root's car tranny has been "looked at" a few times but it keeps kicking. You can always swap in a 4L80 to solve the problem.
Take a look at the ECS car which runs a much smaller blower and is a good bit heavier than the car than ran 9.82. If ECS hit a good 60' they would of been at the same time.
I would actually say do the ECS kit with the Novi 2000.
Old 09-21-2011, 02:37 PM
I would do a 4l80 with a brake but what about the electronics. They were working on a stand alone unit but nothing out yet?
And for the record Jamies tranny has only been out of the car to do the convertor....
How can it be heavier. Dons car is full weight plus the blower, cage and suspension, It was like 4200 with driver at lebanon
Old 09-21-2011, 03:23 PM
LS1Tech Sponsor
Slowhawk's Avatar
I just go by what I've read throughout the years. "tranny was torn down and inspected" clearances checked ect. Really no big deal.
Then they are the same weight.
Now just do some friggin FI already..
Old 09-21-2011, 03:55 PM
Devilish34's Avatar
Theres a lot that comes into play(tuning how you drive it ect) but that trans more times than not sees breakage over 600..
Also unless you match tire height and gears right 1st gear becomes useless.. Some people have been leaving in 2nd and running faster on boosted cars
Old 09-22-2011, 09:08 AM
YOu are correct...it will be a fun winter
Old 09-24-2011, 05:34 PM
SSPerformance's Avatar
TURBO and 4link like you talked about!!!!!
Old 09-24-2011, 06:42 PM
i would love the 4 link, it would look amazing....someone has to come out with a straight axle that bolts into the IRS mounting points
Old 09-24-2011, 08:38 PM
KeithSS's Avatar
turbo
Old 09-25-2011, 06:52 AM
LS1Tech Sponsor
Slowhawk's Avatar
People have done the straight axle but alot of cutting involved. Only problem with the turbo is that the car needs to be 3 bar Sd tuned to run perfectly.
Old 09-25-2011, 07:45 AM
Firehawk441's Avatar
x2
Old 09-25-2011, 07:56 AM
4DRUSH's Avatar
What will be the main purpose of the car. (talking about the 2010 Camaro right?)
Old 09-25-2011, 08:22 AM
INTENESS's Avatar
Scotty go with the blower I think equals easier install less headaches,and it will be like old times with the blower on the car now just have to get Chef to go the track.Blower with a meth kit and it will make more hp to scare the crap out of ya.
Quick Reply: 82mm turbo or ysi or f1c?
