Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Driveshaft balancing NEPA
Old 07-09-2012, 01:36 PM
camar0corey's Avatar
Default Driveshaft balancing NEPA
Are there any places in northeastern PA to get a driveshaft checked and balanced? I'm not even sure if it needs it, but it would eliminate one more avenue in troubleshooting in regards to a vibration the car is suffering from.
Original post on my issue.
I am about 45 minutes north of Scranton. If anyone can point me to somewhere semi-local, thanks!
Old 07-11-2012, 09:43 PM
No where from say Scranton to Binghampton does driveshaft balancing?
Old 07-12-2012, 07:55 AM
sleeperstyle's Avatar
i used Collis years ago. i seem to remember them doing a good job for a good price. i think most of the time you are better off buying a new driveshaft but they will balance a driveshaft for you if you are on a budget
http://collistruckpartsonline.com/
Old 07-13-2012, 02:06 PM
PAGregSS's Avatar
It's not in the region you have specified, but I got my LPE 3.5" aluminum drive shaft balanced at Mapco in Sunbury, PA.
Old 07-19-2012, 10:31 AM
PAGregSS's Avatar
After reading the thread about your issue, I have a suggestion. This may sound odd, but I've seen it make a big difference with a driveshaft vibration. Unbolt the driveshaft at the rear and rotate it 180 degrees and bolt it back up. Essentially flipping the u-joint over.
Old 07-19-2012, 01:33 PM
Thanks for the input, I'll try it out!
Old 08-06-2012, 10:28 PM
gyrene2003's Avatar
So how did that work? I've gots a vibration
Quick Reply: Driveshaft balancing NEPA
