Heat not working need a mechanic in CT?
I just had my coolant drained and replaced. The heat was workind before and now is not working. I must have a blocked heater core. I dont have no leaks and the air blows hard just not hot at all. Anyone that owns a garage or can help me flush it. If it wasnt so damn cold I would try to flush myself. Just pm me if you can help. Could the thermostate be stuck or is heater core that is another ? Anything I could put in that will clear it out on its own? Thanks
My problem dont know where to flush with this cold weather. Anyone want to help im in manchester. I could throw you some cash. The heat would take a little longer to heat up but it worked good. I think i had a sludge buildup somewhere already.would a powerflush unblock it
check your coolant level too, my water pump was pissing out coolant and causing me to not have heat after a couple hours of driving. Didnt leak when sitting or idling.
do they use dexcool or the green schitt
universal green schit. I think the dexcool left gunk because the coolant resoiver dipstick is corroded. I wish i changed in spring. I dont know where i can get it backflushed to cold outside. Wasnt to happy about them not using dexcool. They suck old **** out and put theuniversal in. The levil is fine. I hope its just air.
For the backflush of the heater core. All i need to do is disconnect the two hoses from the water pump? Do i disconnect them both and flush them both or one at a time. I just need to get acces to a hose inside
