Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
MIR WCF Rule Changes For All Motor Class
Old 09-01-2014, 08:35 PM
GARY2004Z06's Avatar
Default MIR WCF Rule Changes For All Motor Class
Here you go.
2014 ALL MOTOR
http://www.importvsdomestic.com/rule...r_domestic.pdf
2014 WCF RULEBOOK ALL -MOTOR (DOMESTIC)
POSTED 9/01/14
M A R Y L A N D I N T ' L R A C E W A Y W O R L D C U P F I N A L S Page 1 of 2
Class Designation: The class designation is: A/M
General Safety: All vehicles must conform with general IHRA safety rules.
Body: Any year vehicle is allowed. Lightweight components are limited to hood, front fenders, decklid, hatches, sunroofs, wings, ground effects, and bumpers only. Roof, Quarter panels, and doors must remain
steel. One-piece front ends are not permitted. No body parts may be removed during competition.
Chassis: All cars must retain complete stock chassis, floorboard, firewall, and frame rails. Notching of chassis for clearance is permitted. Aftermarket “K” members are permitted.
Suspension: All cars must utilize stock front and rear suspension and mounts. Aftermarket front control arms, rear control arms, and sub-frame connectors are permitted. Aftermarket struts and shocks are
permitted. Ladder bars, four links, and wheelie bars are prohibited on all cars.
Lights: Headlights and brake lights are required (one headlight may be removed for induction).
Windows: All windows must be OEM glass.
Interior: Stock dashboard and full interior from front seats forward is required (passenger seat may be removed). Aftermarket seats, gauges, and interior are permitted.
Exhaust: Muffler(s) are required unless vehicle is turbocharged. Exhaust may exit anywhere.
Electronics: Two-steps, data loggers, aftermarket ECU’s, and engine management systems are allowed.
Driveline: Aftermarket axles, ring and pinions, final drive, spools, and differentials are permitted. Other OEM or aftermarket center sections and rear-ends may be replaced only if is a direct bolt in. IRS suspension
cars may convert to straight axle only if it is a direct bolt in.
Transmission: Manual or Auto transmissions are permitted. Any style automatic transmission is permitted. Trans-brakes are permitted. Manual transmissions are permitted to use aftermarket stock-style clutchassisted
transmissions. Sequential transmissions are prohibited. Aftermarket bell housings are permitted.
Clutch: Three discs maximum (any type of disk material is permitted). Clutch must be manually operated by driver’s foot.
Shifter: Shifter must be H-pattern. Strain gauges are permitted. Air shifters are prohibited.
Fuel: Gasoline and E-85 permitted. Alcohol is prohibited.
Fuel System: Electric fuel pumps only are permitted. Aftermarket fuel cells are permitted, and may be mounted anywhere.
Oiling System: Dry sump oil system is only permitted if car was OEM equipped with a dry sump and car is using complete OEM oiling system.
Tires: Maximum size slick or bias ply tire is 28.0” x 11.5”. Any size DOT radial tire is permitted, except 315/60/15, 325/50/15, 295/55/15, or 295/60/15.
8-Cylinder Engines – Chevy LS series
Engine: LS1, LS2, LS3, LS6, and LS7 series blocks permitted. No aftermarket blocks are permitted. Internal engine modifications are prohibited except for aftermarket camshaft, hydraulic lifters,
valve train, and overbore (See chart below for max CID).
Description: This is a cam only class with bolt-ons.
Bolt-Ons: External bolt-on parts are permitted.
Camshaft: LS1, LS2, LS3, and LS6 cars are permitted to run any hydraulic camshaft. LS7cars must run OEM camshaft and OEM valve train.
Induction: Engine must be EFI. All OEM intakes are permitted. The only aftermarket intakes permitted are: BBK intakes, Typhoon intakes, and Fast 78mm, 90mm, 92mm, and 102mm intakes.
Cylinder Heads: Un-Ported as cast cylinder heads only, porting prohibited. Any valve job is permitted. No milling of cylinder head. OEM cylinder heads only are permitted with the following casting
numbers: 241, 243, 317, 706, 799, 853, 862, 8452.
Power Adders: Turbochargers, Superchargers, and Nitrous Oxide are prohibited. All nitrous bottles and solenoids must be removed from car and nitrous nozzles must be capped.
Driveline Block Cylinder Heads Max Displacement Car & Driver Minimum Weight
Straight Axle or IRS LS1 LS1, LS2, LS3 or LS6 heads 348ci. Max 2750 lbs.
Straight Axle or IRS LS6 LS1, LS2, LS3 or LS6 heads 348ci. Max 2750 lbs.
Straight Axle or IRS LS2 LS1, LS2, LS3 or LS6 heads 366ci. Max 2850 lbs.
Straight Axle or IRS LS3 LS1, LS2, LS3 or LS6 heads 380ci. Max 3050 lbs.
IRS Only LS7 LS7 heads 427ci. Max 3050 lbs.
* Manual transmission: Deduct 100 lbs.
* Cars with IRS: Deduct 50 lbs.
* Cars equipped with LS3 Heads: Add 50 lbs.
* LS7 cars equipped with aftermarket cam: Add 150 lbs.
2014 WCF Rules
http://www.importvsdomestic.com/rulebook/
Big weight reductions so we can finally compete.
Old 09-07-2014, 09:02 AM
studderin's Avatar
Old 09-13-2014, 09:18 AM
C5_Pete's Avatar
This is a fun event and Jason has finally given us LS guys a chance.
Time for us to represent!!!
See y'all there.
Old 09-13-2014, 09:53 AM
CGCBandit's Avatar
See y'all there.
I agree!
Old 09-13-2014, 12:12 PM
Zturd's Avatar
See y'all there.
**** this makes me want to bring a domesticated machine this year!!!
Old 09-13-2014, 02:44 PM
Frans96SS's Avatar
In my opinion there will be no LSX cars there again this years. The rules 100% do not favor or even compare to the honda rules... You can not run with the all motor honda guys under the rules. COULD the LSX rules run in the 9.7 range the honda guys run? Sure but 1 MAYBE 2 cars can run those numbers that i know of being 100% legal.
Old 09-13-2014, 03:00 PM
C5_Pete's Avatar
You're very likely correct, Fran. But if we don't show, Jason won't know.
If we get 4-5 LS powered cars and the quickest one goes 9.9s, he'll see we need more help next year.
I figure, it's a start. At least he's doing something to help us be competitive.
Old 09-14-2014, 08:40 AM
Frans96SS's Avatar
I want to bring another car that has ran a best of 9.9 but it has an lsx block.... Which is not allowed.
Old 09-16-2014, 10:40 AM
ATVracr's Avatar
The rules HAVE to be written around those 1 or 2 cars though.
Just saying.
Old 09-16-2014, 10:43 AM
Frans96SS's Avatar
Just saying.
Its a shame. I already talked to jason about it. Its VERY hard to get these cars down to those weights with a driver. You will basically have to take a FULL blown race car and stick a cam only engine in it. Stupid if you ask me...
Old 09-17-2014, 04:54 PM
CGCBandit's Avatar
I tend to agree, 2 years ago I raced this event with my gto. With my cubes I could only run my d1dc p/c....car was basically well wihin the rules....the imports in the same class were gutted race cars with 2 power adders running low 8's. I respect this event(been going to it since it started) and all the hard work put into it, however I would have had to of made over 1000rwhp to compete with the imports(et wise) in the class. Not gonna happen with a stock headed ls1/ d1sc lol full weight 'street car" as this was supposed to be.
Old 09-18-2014, 08:25 AM
ATVracr's Avatar
Looks like Jason is trying to help the LS cars out to me, hell some combos got 300lbs taken off of them.
You cant expect the rule makers to write the rules for street cars, what happens when a well thought out race car shows up under those same rules?
Been there done that with racing my street car and its very hard to be competitive.
See everyone there !
Old 09-18-2014, 08:48 AM
Frans96SS's Avatar
I agree but u and I both know its not easy to get these cars down to the weights that are legal.... 2650 with driver is insane.
Old 09-18-2014, 09:03 AM
ATVracr's Avatar
Our car could run that light easily if it had a N/A engine in it.
And I'm 250lbs... but I agree its insane... lol
If you cant get light you need to make more power.
Build bigger motor?
I would say get as light as you can and run as fast as you can this year.
Jason seems to be pretty good about making changes to get racers what they need to be competitive.
Just wondering what you think needs to be different rule wise?
Old 09-18-2014, 09:35 AM
Frans96SS's Avatar
Build bigger motor?
Ill be racing street fighter but still... Yes jason is a great dude and does do good with rule changes
I was trying to think og how you can limit how fast they go if you allow someone to build an engine... Compression for sure would have to be one of them. Or maybe a max compression for certain cubic inch maybe. Like 347 is allowed 13:1 but a 427 is allowed 11:1
Old 09-21-2014, 08:59 AM
studderin's Avatar
anyone gona be in AM this year?
Old 09-21-2014, 05:10 PM
C5_Pete's Avatar
I plan to be...
Quick Reply: MIR WCF Rule Changes For All Motor Class
