Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Anyone near reading pa have a scan tool that can bleed brakes? I
Old 01-15-2017, 08:59 AM
Floorman279's Avatar
Default Anyone near reading pa have a scan tool that can bleed brakes? I
If you have the scanner, ill pay you to come to my place and bleed my brakes. I replaced the hard lines that go to the rear of the car so since i opened up the abs pump, the abs shoulc be bled
Old 02-17-2017, 06:41 AM
PAGregSS's Avatar
If this is a 4th gen fbody, you don't need a scan tool. Put the car in the air, run it up to at least 5 mph, apply the brakes. This opens the abs block. Leave the car running and bleed.
Old 02-18-2017, 09:24 AM
So as soon as u turn the key off the block closes?
Old 02-18-2017, 02:50 PM
PAGregSS's Avatar
Correct. The braking event above 5 mph causes the block to open. When you turn the car off, it closes back up as it's activated by solenoids.
Old 02-22-2017, 10:32 AM
Ok thanks
Quick Reply: Anyone near reading pa have a scan tool that can bleed brakes? I
