Sticky gas pedal - LS1TECH
Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Sticky gas pedal
Thread Tools Search this Thread
Old 01-21-2005, 08:36 AM   #1
Humanitarian
Location: In the land where the slur juice flows freely.
Default Sticky gas pedal
In very cold weather my gas pedal is sticky. Usally I can press the gas and the rpms will just go up 100 rpm because the way I press the gas pedal is so fluid. Now it's notchy. Like I have to press the pedal a little harder, almost like the cable is stuck or something and the rpm's climb higher and faster because I need to press harder than normal to get the rpms to move.
Once I get past that "notch" it's fine but it's a little annoying. Any ideas?
Joe "Preachers Sheets" DIESO is offline   Reply With Quote
Old 01-21-2005, 08:53 AM   #2
PurEvl's Avatar
open the hood and check the cable? Pull on it(Tb blade) and see if you can feel a stick
PurEvl is offline   Reply With Quote
Old 01-21-2005, 11:50 AM   #3
LS1TECH Sponsor
badpewter-z's Avatar
just from a ilde state joe?
badpewter-z is offline   Reply With Quote
Old 01-21-2005, 12:07 PM   #4
JRcamaroZ28's Avatar
check your throttle body blade...mine did that till i adjusted it a little
JR
JRcamaroZ28 is offline   Reply With Quote
Old 01-21-2005, 12:43 PM   #5
Humanitarian
I just went outside and checked my car. With the car off it was fine, turned it on and it was fine. I can't seem to figure out when it happens but I'll check the throttle cable.
Friggin froze my ***** off out there, jeepers creepers.
Old 01-21-2005, 01:15 PM   #6
LS1TECH Sponsor
with it being 2* this morning maybe now that its 15* it moves eaiser
probbly because it was so cold overnight then
Old 01-21-2005, 01:58 PM   #7
96Z28SS's Avatar
Time to get rid of it and put that money down on a house.
Just kidding!!!!
96Z28SS is offline   Reply With Quote
Old 01-21-2005, 02:20 PM   #8
my dad's 99 silverado did something similar .. it was attributed to carbon build up .. dunno...
Rhode Island Red is offline   Reply With Quote
Old 01-21-2005, 02:22 PM   #9
Humanitarian
Yea and I could sport my **** in speed-o's and a wife beater outside in front of the methadone clinic and tell everyone Iíve got a piŮata with alcohol swabs and clean synergies but itís 10.00 to get into the party.
Always a chance the car would be sold. I'm going to try and save up 5% then get into a condo and get myself a little 4 cycl car and save the Camaro. Civics get something like 34 city 38 highway mpg.
Old 01-21-2005, 03:57 PM   #10
Humanitarian
Cheesy, your dad had a retarded truck. What was he doing, soaking the throttle body in salt water and barnicles? The car was just taken apart not that long ago, cant be that.
Old 01-21-2005, 04:18 PM   #11
LS1Tech Sponsor
I know exactly what it is
Slowhawk is offline   Reply With Quote
Old 01-21-2005, 04:48 PM   #12
Fred99Z28's Avatar
Quote:
Yup, why do you think that TB bypass mod is such a great idea now,lol.
You don't have any coolant going through the TB anymore do you Joe?
Fred99Z28 is offline   Reply With Quote
Old 01-21-2005, 06:38 PM   #13
Krazy98Z28's Avatar
this happened to me once and it was the dam floor mat, when the dumb asses at jiffy lube changed my oil, they vaccumed and moved my floor mat, so when i floored it it would get caught up, scared the **** out of me a couple times til i realized what it was
Krazy98Z28 is offline   Reply With Quote
Old 01-22-2005, 08:10 AM   #14
LS1Tech Sponsor
That's not it Good try though
Old 01-22-2005, 08:12 AM   #15
Moderator
davered00ss's Avatar
Floor mat?
davered00ss is offline   Reply With Quote
Old 01-22-2005, 08:42 AM   #16
PurEvl's Avatar
same as what happenend to curtis's car?
Old 01-22-2005, 09:40 AM   #17
ace68's Avatar
I was thinking TB by pass too.
ace68 is offline   Reply With Quote
Old 01-22-2005, 10:16 AM   #18
LS1Tech Sponsor
The blade is getting stuck when closed.Probly the adjuster is a tiny bit closed too much.The TB bypass is for ice which if there was ice the throttle wouldn't even move.
Old 01-22-2005, 11:11 AM   #19
PurEvl's Avatar
so im right...thanks for claering that up
Old 01-22-2005, 11:14 AM   #20
Fred99Z28's Avatar
Well if it was out of adjustment...then why once it got warmer outside would it all of a sudden free up & work normal? LOL
I still say it's TB bypass. Don, have Joe bring his car over, put it your garage (heat) & check the adjustment theory J/K-Fred
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
