car died while running the 1/4 - LS1TECH
Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Thread Tools Search this Thread
Old 07-08-2006, 12:01 AM   #1
68ss_00ss_87_95's Avatar
Default car died while running the 1/4
so like the title says i got in line for my first run the whole night at NED and as i shift into 3rd my exhaust got real loud...like the coupling came off from the header to the cat...so as i go into 4th i hit 6200 and the car shut off and coasted past the line...it wouldnt start at all but it would turn over...like it has no spark...checked all the fuses...all ok...it pulled 1 code...anti-theft...i figured maybe the car is locked out from turning over...disconnect the battery and wait about 10 minutes and still wont start...it starts to make the noise like it needs more fuel but when i give it gas...nothing...what should i look for...or where should i start i guess?
Thanks
Ted
68ss_00ss_87_95 is offline   Reply With Quote
Old 07-08-2006, 05:23 AM   #2
Are you out of gas, I know pretty basic.
BrentC5 is offline   Reply With Quote
Old 07-08-2006, 11:13 AM   #3
ace68's Avatar
blown motor? does it spin faster than normal wile turning the key?
ace68 is offline   Reply With Quote
Old 07-08-2006, 07:08 PM   #4
NateLS1's Avatar
there is a test port on your fuel rail, you can test for fuel pressure there. just look for a little black cap.
NateLS1 is offline   Reply With Quote
Old 07-08-2006, 09:45 PM   #5
Your first post is a little confusing...
You have a crank, no start...
or you have no crank when you turn the key.
slayer6x6 is offline   Reply With Quote
Old 07-09-2006, 01:42 AM   #6
Something similar just happened to my car. It turned out that the alternator was fried.
02 Camaro SS is offline   Reply With Quote
Old 07-10-2006, 12:03 AM   #7
it still cranks the same speed as normal just seems like its not getting fuel...i have over a 1/4 tank, i thought maybe air got in the lines somehow so i tried givin it some gas when it was cranking, still nothing...relays/fuses are ok...ill try to hook up a fuel pressure gage to the rail...i really hope its not a blown motor since i only put 7000 miles on this 1...i guess i can buy an ls2 if this ones trash....
Old 07-11-2006, 06:17 PM   #8
NateLS1's Avatar
i know its not that accurate of a test, but you can hold the schrader valve in on the test port while someone is turning it over to see if fuel keeps squirting out. if the fuel pump is junk nothing should be coming out obviously.
Old 07-11-2006, 06:40 PM   #9
CamaroSS621's Avatar
check for any codes. you may of thrown it into "safe mode"
CamaroSS621 is offline   Reply With Quote
Old 07-11-2006, 07:59 PM   #10
Moderator
davered00ss's Avatar
Let us know what you find.
davered00ss is offline   Reply With Quote
Old 07-13-2006, 12:20 AM   #11
heh...i poked around under the car and found some wires....they lead to....another fuse! go figure it was sittin just under my linelock solenoid....now my question is why did the fuel system fuse blow? the exhaust coupling on the driver side came undone but didnt completely dump, could that have affected the car at all? the fuse was a 20 amp if it matters...god i feel like an idiot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
