Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Failed sound level check at Autox
Old 04-22-2007, 08:20 PM
z28bryan's Avatar
Default Failed sound level check at Autox
Well I need to do something to quiet my exhaust down slightly. I was at 97.something on the decibal meter at the 75 foot away mark. In my local club I need to be under 95. I think its even lower for the NER club and I know they would toss me.
I've only had 3 different setups. 1 was stock, 2 was the corsa exhaust, 3 is what I have now:
Kooks LT's with high flow catted ypipe
corsa catback
avg cam 224/228 .560/.570... something on those lines
So I'm not sure exactly what would be the best balance between not losing too much power yet keeping the sound down. Maybe I only need to toss on an exhaust tip that points downward?
I figured a lot of you guys have heard and compared different setups, especially Slowhawk and crew
ps... I'm f*in pumped because the sox just hit 4 solo hr's in a row from the point where I began typing this until when I posted this thread, lol, completely sick
Old 04-22-2007, 08:56 PM
ace68's Avatar
that was sweet go SOX"S
Old 04-22-2007, 09:05 PM
Ojustracing's Avatar
Hey Bryan why not stick a bullet style muffler in the I-pipe. I ran Mac-mids, ory, moroso Sprial flow, and GMMG at Lime Rock and didnt get tossed. If you are looking for it to be toned down a little a a regular bullet muffler should do the trick if you are looking for a bigger noise reduction the sprial flow would be the ticket.
John
Old 04-23-2007, 09:34 AM
z28bryan's Avatar
Yeah I think the mids help you out there. I have longtubes. I may consider mids, even if it puts me down about 20 horse. Maybe a cutout for the speedway events, with a quiet exhaust closed during autox.
I'm wondering if doing all this will mess up my A/F ratio and will need to be retuned
Old 04-23-2007, 09:49 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Thats weird, I have a corsa, LT's with dynatech catted Y pipe, my car is a lil louder then stock, its nothing crazy. I think your highflow is looser then most.
Old 04-23-2007, 09:56 AM
z28bryan's Avatar
I have a cam too though. If you had a cam, you would be a bit louder depending on how big it is.
Old 04-23-2007, 09:57 AM
Moderator
davered00ss's Avatar
Go with an SLP Dual Dual cat-back. Flows prety good and probably the quietest cat-back you can put on.
Old 04-23-2007, 10:52 AM
LS1Tech Sponsor
Slowhawk's Avatar
I agree with Dave. You can try a Magnaflow that is cheaper.Should be quieter than what you got.If all else just throw a bullit on there too.
Forget the midlengths.You have nice headers already.
What some people don't understand is when you add a H/C setup with raised compression the exhaust will get louder and change tone.I hated my Corsa after doing a H/C setup.
Old 04-23-2007, 11:05 AM
Internet Mechanic
Welp, I know nothing about the car aside from the post, never saw head work of any sort and saw a small cam. I know tone changes. I know the diff of a corsa with cats and without. My 383 was tooooo loud with no cats and a small hotcam. As for Db level, I would think its how well the cats were working to deaden the sound.
Stock cam, stock heads, with a new catted Y I can honestly say its louder but close to stock.
Eitherway, I hope it gets fixed soon so you can run.
Old 04-23-2007, 01:08 PM
z28bryan's Avatar
That sounds like a good solution. If the slp dual dual is quieter, I'll get that over the Magnaflow. Where does the bullit go, between the cats and muffler?
The Corsa performs a pretty obnoxious exhaust belch when you lift the gas after WOT with my cam. Lots of people think its cool, but it gets annoying after a while.
Old 04-23-2007, 01:34 PM
Bowtie Boy's Avatar
http://store.summitracing.com/partde...5&autoview=sku
Sound reducer cones for headers/mufflers. There is little or no power loss from these.
Old 04-23-2007, 05:14 PM
ace68's Avatar
I used the cones they didn't cut me back too bad and did work.
Old 04-23-2007, 06:32 PM
LS1TECH Sponsor
badpewter-z's Avatar
dual/dual quiet and doesnt hurt power to much untill you start pushing ALOT of compression and power but still quiet
Old 04-24-2007, 06:18 AM
Zturd's Avatar
Just a shot in the dark but something i considered doing to the vette cause its to loud and may help you anyways. Borla has the plate system with reduced size holes in it. They are just a thin sheet of metal that you could put in where your catback comes together somewhere and it would be like a gasket and a smaller size hole. Giving you mroe torque but making the car much quieter and cheap easy in and out??? Just a shot in the dark.
Old 04-24-2007, 07:27 AM
z28bryan's Avatar
Can you still buy the dual dual these days?
Old 04-24-2007, 07:51 AM
iamsickofitall's Avatar
only used ones
Old 04-24-2007, 08:06 PM
Moderator
SLP doesn't sell them anymore?
Old 04-24-2007, 08:29 PM
nope, they stopped sometime last summer. when i was looking for one, SLP said speed inc. was pretty much the only shot i had at getting one that might be sitting on a warehouse shelf somewhere, but they were sold out when i called. i just ended up getting a used one from a friend.
Old 04-24-2007, 09:56 PM
F-Bobby's Avatar
wtf they have a limit as to how loud you can be on autox? i guess im never going to one my car wakes the dead.
Old 04-25-2007, 09:32 AM
z28bryan's Avatar
Some of the residents around Devin's complain I guess. Go figure, what were they thinking when they moved next to a military base and airfield?
In any case, my exhaust is annoying the hell out of me so fixing this is also something I want to do for my ears.
So say I went the Magnaflow/bullet approach how does that get setup? I looked up bullet mufflers and saw that there's two loudmouth types. Would this setup be like combining a Magnaflow and Loudmouth exhaust together? Doesn't the Loudmouth resonators go between the rear axle and the y-pipe?
