Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
fuel pump
Old 05-05-2007, 07:53 AM
peterock98's Avatar
Default fuel pump
Yesterday I installed an oem fuel pump and now the gauge in the car is stuck on full.It was was working when I first stared it up.I put in two gallons then drove to the gas station and filled it up and now it not moving any ideas?
Old 05-05-2007, 08:14 AM
CATDIESEL's Avatar
could the arm for the float be bent from install ? stuck on top of the pump housing??
Old 05-05-2007, 08:53 AM
Internet Mechanic
BlackScreaminMachine's Avatar
its the floater.
Old 05-06-2007, 09:05 AM
JSPERFORMANCE's Avatar
or the sensor itself might have gotten damaged..
Old 05-06-2007, 10:25 AM
01Z28M6's Avatar
When the signal from the sender is lost the gauge stays on full up because resistance is infinite. Check your connectors and wires first.
Here's some more help if you need it:
http://shbox.com/1/4th_gen_tech2.html#fuel_gauge
Old 05-06-2007, 04:19 PM
peterock98's Avatar
Today I filled up the gas tank to the point where gas poured out ,I hoped it would free up the float & still no dice.I'll re-check the connections and wires tomorrow ...
Old 05-06-2007, 04:22 PM
peterock98's Avatar
Is there a fuse or relay that controls the needle?
Old 05-06-2007, 07:12 PM
2MCHPWR's Avatar
want me to take her for a test drive? haha whats up bro? when did you rebuilt the motor?
Old 05-07-2007, 06:18 AM
peterock98's Avatar
Everythings kool, how about you Scottie ?Jay Fisher Pontiac rebuilt it a few 24's ago .When are you going to help me fix my fuel gauge lol?
Old 05-07-2007, 07:31 AM
01Z28M6's Avatar
There is a fuse for your instruments but I think it is for the lights in the instruments only - you can see it in the fuse block. The way most gauges work with senders is to supply a small current to the circuit between the gauge and the sensor, sometimes only 5v and then add resistance to lower or "meter" changes from the max signal voltage. As the sender in the tank is moved with a higher level of fuel, more resistance is added, less voltage is in the circuit and the gauge reads higher. That is why disconnecting the wire altogether pegs the gauge to full up. Logically that seems backwards but with the fuel gauge apparently lower is higher.
Old 05-08-2007, 07:55 AM
peterock98's Avatar
I called a friend and he said there was a rubber peice that I was supposed to take off the old pump for the float.The dealer said it was a direct drop in.
