Springs and Cam.
Springs and Cam.
I recently had comp 918 springs put in with my cam 232/234 595/598 112lsa what do you guys make of these springs? I thought pretty highly of them which is why I got them, but I was interested in your opinions. Thanks Ben
Originally Posted by Slowhawk
Truthfully, I would of never used 918's with that Cam. Yes,they are rated for it but we only use them up to .580 lift. P/V is probly .100 on that Cam and a good over rev with probly eye lash the pistons.
Race your car!
they should be fine..... but I'd have them pressure tested after say 8 to 10 thousland miles to make sure they are still o.k. A cam like you went with they should be o.k.... but after abotu 10K I'd check the springs to make sure they are still strong enough. If ya see any getting weak, then ya know what needs to eb done, another set, same thing or a little stiffer.
Originally Posted by z28bryan
I think their advertised to use a max lift of around .580
LS1Tech Sponsor
Originally Posted by JL ws-6
If you're that worried about it then change them out sooner then later... you are running an auto so the over-rev is less of an issue then with a stick car... but if it's a piece of mind you're after then do it as soon as you can IMO.
holds it yes, but the overrev situation isn't as much a threat, as long as the tranny's working right.
Internet Mechanic
the fact is no matter how good the spring is, if your running an aggressive spec'ed cam or the lobes ramp really quickly its going to hammer the springs, eventually even the best have to be swapped out, so for now, make a mental note to do a spring swap during the off season and depending on how close to 10-12k you are.
LS1TECH Sponsor
id be a little leary with the 918's and that lift not to mention im sure its aggressive ramp rate. even if its just peace of mind id swap them for a good dual spring . reason being if one does let go do you really wanna learn the hard way
Internet Mechanic
Either call the company that ground you the cam, looks like HPE, ask what they recommend, I assume they give you what was expected with the cam, unless you bought everything seperate.
OR call eastside and see what they think and buy the stuff through them, either way you should be able to get a good idea.
I mean the cam is in there, it works, its not dropping valves, its making power, so no need to rush and kill yourself for doing it.
