Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Need ideas on moving large steel plate
Old 03-03-2008, 12:25 PM
ss1
ss1's Avatar
Default Need ideas on moving large steel plate
I have a racecar chassis setup surface plate that i'm going to sell to a friend. It's 20' long, 8' wide, and 3/4" thick, and weighs in at 4900lbs. We need to figure out a way to move it to his garage about 20 miles away. Are there any companies that have equipment large enough to pick this thing up & deliver it? I called the place it was purchased from, American Steel, and they offer no such service. I don't know where else to look. Any ideas guys???
Old 03-03-2008, 12:27 PM
99Hawk6spd's Avatar
A septic tank hauler might be able to pick that up and haul it, no guarentees though. Just an idea.
Old 03-03-2008, 12:53 PM
meatyz's Avatar
is it flat on the ground?
Old 03-03-2008, 01:38 PM
Ping King's Avatar
sell him your garage lol..im sorry i had to.
Old 03-03-2008, 01:47 PM
ss1
ss1's Avatar
Yes, it's laying flat.
Old 03-03-2008, 01:48 PM
ss1
ss1's Avatar
The plate is mine, but the garage isn't!
Old 03-03-2008, 01:51 PM
2000LS1TA's Avatar
Almost any construction company should be able to do it for you. Just weld a D ring in each corner of the plate, run a chain through it, pick it up with a backhoe, put it on a flatbed and bring it to his house.
Old 03-03-2008, 03:35 PM
WJ SOM SS's Avatar
Many small Crane or Rigging companies have portable electro-magnets for their rubber-tired cranes that can come to your site and pick the plate up and swing it onto a flatbed-semi for the 20 mile trip....no big deal. WJ
Old 03-03-2008, 04:05 PM
Big Mike's Avatar
First you are going to need something strong enough to lift the plate. I own a construction company and use these roadway plates all the time. The best thing to do is torch (burn) 2 holes in the top 2 corners of one side of the plate.
Before you burn the holes you are going to have to chock up one side of the plate, this way you can slide your chain or binders through. Your best bet is to use a the front end of a backhoe to lift the plate. But that's only half the battle. You need a trailer big enough to transport that plate. A tag along trailer will do, being pulled by a dump truck.
Old 03-03-2008, 04:07 PM
ss1
ss1's Avatar
Thanks WJ, thats what I wanted to hear. I wasn't sure if such a thing even existed. I've found one guy who said he could move it, but i'm not too sure how he would go about it.
The problem with most methods is the possibility of bending the damn thing if they're not too careful with it. It has set screws to level it out once its im place, but if its not completely flat we're in trouble.
Old 03-03-2008, 04:13 PM
Big Mike's Avatar
3/4" thick steel, you will never bend that in a million years!!
Old 03-03-2008, 04:15 PM
ss1
ss1's Avatar
Thanks for the info Big Mike. I'd love to just drag it out of the garage and load it on a flatbed contruction trailer. There is actually one of those sitting in the yard that belongs to the septic tank guy who ises the garage with me. The only problem is i'm sure the guy buying the plate will not want to cut any holes in it. That is what is making it such a pain in the ***.
Old 03-03-2008, 04:16 PM
ss1
ss1's Avatar
Haha!!! We can only hope so. If theres a will, theres a way...
Come to think of it, what size chain would we need to safely move this thing? There are already 1/2" holes drilled 6" from each of the four corners, and enough room under the sides to trig it up a little bit. Hummmmmmmmmmm
Old 03-03-2008, 04:25 PM
WJ SOM SS's Avatar
Salvage yards also have these electro-magnet setups, as well as some riggers. They pick up tons of steel at once w/these magnets. Other than the magnet method, you're gonna have to torch-burn holes in the plate to attach lifting lugs or shackles....like Big Mike said...good luck. WJ
Old 03-03-2008, 04:31 PM
styoung's Avatar
you would be surprised, i wourk with 2" plate that is 8' x 8' and we cut 48" diamter flanges out of and they are alway bent a little, not enought to notice until i machine it.
maybe if you can get a couple pieces of pipe under it, weld a pad eye on the front and hook a comalong onto it and roll it on a trailer.
Old 03-03-2008, 08:14 PM
Zger's Avatar
Call a towing company. They can haul it on a flat bed/rollback. Shop around for the best rate. Shouldn't cost more than $150 to get it moved. I drove a rollback for almost a year delivering fork lifts, bobcats and other small equipment. It's really not as complicated as some folks on here are making it out to be.
Old 03-04-2008, 07:30 PM
dogger's Avatar
I'm sorry but you must be city folk and not hillbillies!!! I'm waiting for the suggestion of using a few fence post a ramp and trailer with a winch.
Old 03-05-2008, 09:18 AM
bgblockelcamino's Avatar
if you already have 1/2inch holes are they threaded? get some eye rings to screw in there. then pick it up with tow truck?
Old 03-05-2008, 09:50 AM
Big Mike's Avatar
5/8" will be more that sufficient...
Old 03-05-2008, 09:52 AM
Big Mike's Avatar
You have to be careful. The plate is 8' wide which means if it over hangs your tailer or flatbed you are going to need an oversize permit and an escort to move the plate.
