Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Stripped the crank threads trying to get the stock pulley off.. can anyone help??
Old 07-13-2008, 08:03 PM
CJDZ24_Z28's Avatar
Default Stripped the crank threads trying to get the stock pulley off.. can anyone help??
Well after owning all the f-bodies i have and tons of projects and fixed i finally screwed up. I stripped the threads inside of the crank trying to remove the crank pulley. The only reason I went to replace the damn pulley because my belt slipped off the stocker 2 times already. Anyway I have read that people re-threaded this with a tap or used Helicoils. Now I'm gonna have to drive my FRC everyday. Anyone have any experience with this from the area? Thanks
Old 07-13-2008, 08:29 PM
454mag's Avatar
Carlton, not from the area but heli-coil will fix the problem. They are stronger than the parent material. I have a OTC GM puller for stock pulleys if you think it will work to pull the pulley free to you . lmk ted
Old 07-13-2008, 08:50 PM
CJDZ24_Z28's Avatar
454 sent you a PM. I def need more info on the Heli Coil!
Old 07-13-2008, 10:46 PM
chevrunner21's Avatar
i did it with an old 1g sbc(350 swapped in my 80 cutlass) ****** pepboys puller dug straight into the threads so i through a heli coil in and continued to beat the life outta the car. it's been awhile so i dont want to tell you bad info but if you buy a kit it will come with instructions and im sure most mechanics wouldnt mind telling you exactly how to do it.
Old 07-14-2008, 09:07 AM
8 second mod
Noyzee's Avatar
you can buy a arp bolt its a little longer and will reach new threads or i think its the blue cranck bolt for a super charger pully. again its longer to reach new threads. a healie coil will work as well, shouldnt throw off any balance
Old 07-14-2008, 09:51 AM
Nick@HSW's Avatar
Carlton,
Just heli-coil it. Its easy to get a right angle drill in there. Or like noyzee said above, if there are enough threads you might be able to catch some deeper ones. Just clean up the damaged part first though.
Old 07-14-2008, 06:34 PM
CJDZ24_Z28's Avatar
Thanks fellas.
What size Heli-Coil do i need? I couldn't even find the right size tap 16x2.0 Anywhere!! ALso I damaged the threads and didn't even get the stocker off yet
Nick,
I would bring the car to you guys but the tow would cost a fortune
Old 07-15-2008, 12:00 PM
Mean Green z28's Avatar
A Helicoil kit will come with the drill (or atleast give you the size to use) and the tap for the Helicoil, and the insertion tool.
Old 07-20-2008, 09:40 PM
CJDZ24_Z28's Avatar
I would like to thank everyone for the responses. Especially thanks to lastcall190 for hooking me up with the longer bolt and the install tool. I was able to tap the threads and once i got the new pulley on I was able to use the brand new GM crank bolt! I would also like to thank 1 hot SOM WS6's boy for the nice LS1/LS6/LS2 crank pulley remover made by blue-point part number YA9740B!! I would recommend this to anyone It removes the crank pulley without touching the treads!! The TA is gonna get a 120 mile roadtrip tomorrow. I'm so glad i don't have to daily drive my C5 anymore
