New best, not great but better.
8 second mod
however i nicked a head gasket. guess i cant complain, they have been on for atleast 60 hard 9.0-9.1 passes, the new best looked great, AF was spot on, and timming on the plugs where perfect. im pretty sure i got the gasket last time out because i had a little water/sludge when i did the oil change. anyway heres the run down
un loaded, threw a tune in it, put 2 tenths delay in the nitrous, 250 jets and tuned it safe.
went up, car hit good then when the spray kicked on it blew the tires a little bit car drove left had to lift a bit to shut off the spray, got back in it, short shifted it by about 300 rpm short (7200 rpm, and really i should have shifted at 7800) and ran it out the back.
ended up going an 8.77 @ 154.xx with a 1.34 short time.
125 in the 1/8th, got back and saw a couple drops of water, so i called it a day. started to take the car apart at the track, just got the head off and i hit #3 just a tad, i have a gasket here so im going to clean it up and throw it back together. hope to run a little faster tommorow.
gatta run. work time. vid to come
8 second mod
thanks guys, i know she has more in it, got another new best first pass today, but had to get in and out of it, somthing is up with my transbrake and it wasnt holding correct, im going to go threw the wire tonight.
8.70 155 today that was on and off out of the hole and i shut it down around the 1,000 foot mark. a was way rich and the car was nosing over. next pass out the used headgasket i threw on last night puke itself out. ordering new gaskets tonight
