Florida Members Fun, sun and LS1's
Anyone replace floor pans before?
Old 06-01-2009, 03:25 PM
erikthegoalie's Avatar
Question Anyone replace floor pans before?
Hey everyone- I've got some holes in the floors and toe boards of my 65 Buick. I was thinking about cutting the old s/m out and welding in new stuff. I am a decent mechanic, and have some skills as far as fabricating goes, but am by NO means a seasoned body man!!!
Just looking for tips and tricks before I cut!
Thanks
Erik
Old 06-02-2009, 09:16 AM
blk/slvr02ss's Avatar
Its not that bad if you get the floor pan sections.Keystone has the section for almost all the cars .Just lay the section on top of the old floor trace it w/ a marker then leave yourself a inch or 2 then cut out the old one then weld or rivet the new one.
Old 06-02-2009, 12:27 PM
ec_nova's Avatar
make sure you install them properly otherwise they'll fly off when you hit the NAWZ!!!!
...sorry I had to
Old 06-08-2009, 11:18 PM
oange ss's Avatar
full or partial ?
Old 06-13-2009, 08:33 PM
SKI
SKI's Avatar
Drill 1/4 holes every 2-3 inches around the parimeter of the new peice and spot weld it like the factory did .
Old 06-14-2009, 12:59 PM
Moderator
jimmyblue's Avatar
Depends on what kind of old car this is. I've brazed in (don't
recommend) donor sections cut from another car, when I
thought I was "restoring" something. But for a beater, some
window screen and roofing cement works pretty well. That
aluminum roof coating makes a real good undercoating too,
stops rust real well.
If you are tacking and not running a continuous bead, you
should get some body seam sealer and pack the seam before
it sees the wet (after cathodic protection and primer).
Old 06-22-2009, 12:55 PM
thanks guys...it is a 65 Buick that has been backhalved...the front floors and toe boards are rotted. I suppose this will be a PARTIAL replacement towards the front of the car. Thanks for the tips!
Quick Reply: Anyone replace floor pans before?
