Florida Members Fun, sun and LS1's
Eagle auto in Vero Beach
Old 07-16-2009, 10:03 AM
corvet786c's Avatar
Default Eagle auto in Vero Beach
Just would like to say Matt did my head and cam install. He did a very good job. Anyone looking for h/c install should go to him. Very reasonable too.
Old 07-16-2009, 02:52 PM
Titanws6's Avatar
Who's gonna do your tune.....ready see what kinda numbers you will be putting down, subscribed.
How much for the H/C install if you mind me asking?
Old 07-16-2009, 03:13 PM
corvet786c's Avatar
Well he charged just $500.00 for head swap and $50.00 to change out engine mounts. I will be using the vinci/crane tuner for now on a dynojet. I figure when I get my fast 92/92 then I go 85mm MAF then hp tuners.
Even now not tuned with tuner the car pulls hard from 4000 up. I also have spark advance built in tuner.
The dyno will be a couple of weeks and I will post results on this entire board.
Old 07-16-2009, 03:42 PM
JohnHF's Avatar
ive met matt before good guy
Old 07-16-2009, 03:47 PM
corvet786c's Avatar
Yes really nice?? He worked very hard on my set up?
Old 07-16-2009, 10:07 PM
Titanws6's Avatar
Not a bad price, I take it you supplied all the parts...have you figured out your valvetraine noise yet?
Old 07-17-2009, 02:57 AM
corvet786c's Avatar
I supplied all the parts, Well it seems to be coming from driver side only.I am goin to take it back today to him. There was also a slight ticking before head swap. I guess it is just these engines.
I would also like to note. I took my car out on hwy yesterday and MAN from 4000rpms to 6500 just pulls like a raped ape. I should of did this mod years ago. But I wanted the best. So I had to wait.$$$$$. I
Old 07-17-2009, 06:16 AM
Mike Norris's Avatar
Congrats and the AFR's are as good as it gets. On the lifter noise I would be curious how much preload it came out to have with what pushrods as that is a must check item on a head install.
A little advise while you wait to be tuned though. Unless you have a wideband in the car I would not be doing any WOT runs though it is very tempting and feels good. It may be just fine, but if the tune is off enough you could end up taking a step backwards unexpectedly. Just my two cents.
Mike Norris
Old 07-17-2009, 08:04 AM
corvet786c's Avatar
Mike Norris
Thanks for response mike, You can never go wrong by adding more fuel to set up which I did cause of #30lb injectors. The ticking noise seems to be coming from driver side. I had contacted roger vinci. They had put afr's on johns red c5 and he said to use the 7.350 pushrods.
Old 07-17-2009, 10:22 AM
Yeah, the 30lbers will add fuel with no ther changes.
The 7.35's may work but it still all depends on the base circle of the cam, are the heads milled as well as factory tolerances of the block as far as cam location. I have had to use anything from 7.35 to 7.45 pushrods to get proper preload for sure. How much preload did you end up with??
Like I said, everything should be close enough, I am just one of those that would rather be safe then sorry and verify all is good instead of assuming they are. Good luck for sure.
Mike Norris
Old 07-17-2009, 07:20 PM
69Nova's Avatar
Default About your post
Hey I live in sebastian FL and am looking for a person to do my LS1 swap for me any advice.
Old 07-18-2009, 05:54 AM
corvet786c's Avatar
Yea take it to this guy I am talking about? What all are u having done to your car??
Old 07-18-2009, 07:19 PM
69Nova's Avatar
I am doing an LS1 swap with a 4l60E auto tran's in my 1969 Nova. I allready have the motor, tran's and wiring harness but it looks like the harness may need a little help or may have to buy a painless wiring harness. Do you know if that shop in Vero has history of LS1 swaps I just dont wanna get involved in a shop that its there first one and then they quote me one price then relize its way more work and it doubles or tripples.
Old 07-19-2009, 04:41 AM
corvet786c's Avatar
I am sure he can do it he has all the tools. All I know is he done my head and cam swap.
EDIT: non-sponsor contact info removed
Old 07-22-2009, 11:24 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Keep non-sponsor contact info out of the thread please.
Quick Reply: Eagle auto in Vero Beach
