Florida Members Fun, sun and LS1's
made 400hp..
Old 07-31-2009, 05:30 PM
stangslayer98's Avatar
Default made 400hp..
just had the car tuned it made 400 at 6300rpm 360ft@5200 things done so far h/c/ LT and an LS6 intake.. is there any where i can improve that will net a noticable difference......maybe rocker arms port the heads a bit i would like to see 450 to the wheels, thanks for any input
Old 07-31-2009, 06:12 PM
SKI
SKI's Avatar
Talking
Spray it
Old 07-31-2009, 06:13 PM
SKI
SKI's Avatar
What heads?What cam?
Old 07-31-2009, 10:53 PM
5.3L heads 232 234 i wanted to stay away from the bottle
Old 08-01-2009, 09:45 AM
TLewis4095's Avatar
Auto or stick? If thats an auto your doing VERY well for the mods noted.
Old 08-01-2009, 01:57 PM
troopercar's Avatar
Almost exactly like mine, wanna race?
Old 08-01-2009, 02:07 PM
philsblwnz28's Avatar
250 shot and close your eyes
Old 08-01-2009, 11:18 PM
could i get 50whp with aftermarket catback bigger TB and porting the heads a bit......the car is a manual
Old 08-01-2009, 11:49 PM
86 IROC's Avatar
Doubtful. I make mid to upper 400 RW #'s, it takes more than a few odds and ends to pick up 50 RWHP. What is done to your heads? Any flow sheets? Or are they basically stock 5.3L heads?
IMO, you're going to need every last little bolt on, a cut out, a set of heads that flow around 300cfm - yet retain good mid lift flow, and a cam that matches.
Remember - peak #'s aren't everything. Power under the curve is where it's at.
Old 08-02-2009, 01:21 AM
the heads are the 2.5 prc's i was thinking maybe they can be worked a bit, along with nice cool weather and a prayer illl get the 450 mark
Old 08-02-2009, 09:42 AM
TLewis4095's Avatar
Not many cars with your mods as quick as yours Troopercar....looking for victims?
Old 08-02-2009, 11:59 PM
Doc
Doc's Avatar
Nice numbers. Are you getting all of what you could have so far to the ground with the suspension you currently have?
Old 08-03-2009, 06:37 AM
troopercar's Avatar
always
Old 08-03-2009, 12:55 PM
CriminiSS's Avatar
Look into a fast intake and a cutout those 2 alone should boost your hp #'s decently
Old 08-03-2009, 01:23 PM
firstinlastout86's Avatar
Nice what LSA? got any sound clips/vids?
Old 08-03-2009, 02:03 PM
R1ch's Avatar
I made 400 HP with a 6 speed on stock 241s with a 232/234 cam....
Old 08-03-2009, 05:48 PM
rich was that on a mustang dyno? how high did you spin the motor..i might need to get a better intake along with a TB and a better catback or cutout like crimini said.....not sure what LSA the cam has......doc probably not i have no suspension mods aside from lowering springs
Old 08-03-2009, 07:12 PM
kwiksilverz28's Avatar
Supercharger. You will not regret it.
Old 08-04-2009, 10:15 AM
Doc
Doc's Avatar
Get the power to the ground. A lot of potential untapped at the level of power your car already has with the basic stock suspension.
Old 08-11-2009, 07:12 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
As mentioned:
#1 - a complete power curve rather than the peak is what you should be looking at.
#2 - if you can't put down the power you have now, why worry about more? I'd take a look at suspension upgrades first.
Derek
Quick Reply: made 400hp..
