Florida Members Fun, sun and LS1's
New (and I mean brand spankin' new) Project
Old 03-31-2010, 12:01 PM
JEB99TA's Avatar
Default New (and I mean brand spankin' new) Project
Reposted due to posting in Classifeds by mistake.
2010 Mustang... bare bones - ready to build ... LS powered. License plate lives on ... JEB99TA ... tribute to my old my old gal I had to put to rest ... RIP. 'That red Trans Am'.
This and a 200 wet kit - coming soon in a town near you.
LS9 Tech Specs 638 Horsepower
Part Number:
19201990
Engine Type:
LS Series Gen IV Small-Block V-8
Displacement (cu in):
376 cu in (6.2L)
Bore x Stroke (in):
4.06 x 3.62 (103.25 x 92mm)
Block:
Cast-aluminum with 6 bolt, cross-bolted main caps
Crankshaft (P/N 12598610):
Forged Steel
Connecting Rods (P/N 12624231):
Forged titanium
Pistons (P/N 12598634):
Forged aluminum
Camshaft Type (P/N 12605527):
Hydraulic roller
Valve Lift (in):
.562" intake / .558" exhaust
Camshaft Duration (@.050 in):
211 degree intake / 230 degree exhaust
Cylinder Heads (P/N 12621774):
Aluminum L92 style ports; as cast with 68cc chambers
Valve Size (in):
2.16 intake / 1.59 exhaust
Compression Ratio:
9.1:1
Rocker Arms (P/N 12569167 int):
Investment-cast, roller trunnion
Rocker Arms (P/N 10214664 exh):
Rocker Arm Ratio:
1.7:1
Recommended Fuel:
92 octane
Maximum Recommended rpm:
6600
Reluctor Wheel:
58X
Balanced:
Internal
It's Here!
Old 03-31-2010, 01:32 PM
stealth71's Avatar
Should be a cool swap. Nothing like ripping a brand new car apart to put a badass power plant in.
What trans and rear you planning on?
Old 03-31-2010, 02:17 PM
86 IROC's Avatar
So you bought a base model V6 car to cut up? It will definately be a unique/one of a kind swap.
Old 03-31-2010, 03:19 PM
1998MysticZ28's Avatar
I hope this is not a joke, that would be a bad *** project.
Old 03-31-2010, 04:02 PM
RsSean's Avatar
Best of luck to you sounds like a really neat idea.
Old 03-31-2010, 07:14 PM
JEB99TA's Avatar
Thanks guys ... it's still a long row to hoe and it'll take time to get it done right. Keeping it somewhat under wraps for now ... suspension comes first ... driveline second, weight reduction 3rd, and once that's all done, the motor will be blueprinted and built. It'll be as quiet as is possible and won't see a lot of street useage. After I parted out the TA, I saved every dime I could and then bought my truck ... be needin' a trailer in the Spring, I guess.
The car is up North of here with measurements being taken to see how much it will need to be cut up. Chuck at FLP will be involved along with Dave at Yank and the boys at Strange Engineering ... these are the guys who have made things right with me through past breakages and problems. Others haven't.
I plan to seek advice from Jake LaMotta on the suspension and chasis side of things. Jake's done a lot of go-fast $hit in his time and most folks know he is very well respected in the racing community and he has a lot of connections. I may consult MTI for the motor and nitrous install ... just still have a lot of consulting and research to do.
I don't come on much because I've been without a race car, but, once this build is done, I'll be back alive on here. Everybody take care and don't street race like I used to do ... not so many years back. No family deserves to lose a family member ... give it all ya' got at the dragstrip, though and race safe (if there really is such a thing).
Ryan, keep that green machine goin' strong. I have a kinda' personal interest in that car for some strange reason.
Quick Reply: New (and I mean brand spankin' new) Project
