Lashway Motorsports Catch Can Special!
Through the end of September, all of our cans and breathers are on sale! Please call or PM for pricing! 954-971-4383
Our PCV oil catch cans are designed specifically for use on N/A as well as FI applications (FI units feature additional check valves). Fits any LS engine, even the 2010 Camaros equipped with the LS3 and L99.
What makes the Lashway Motorsports catch can work so well? For one, they are larger than most cans on the market, 1 qt to be exact. This larger surface area allows the captured oil mist to cool which promotes oil collection at the bottom of the can. It also descreases the need to drain more frequently!
Our cans also feature a convenient drain and hose at the bottom of the can. Nothing worse than having to unscrew/unbolt your can from the head just to drain it! With our drain valve, you can easily remove any deposited oil in seconds, not minutes!
Made with high quality aluminium, and quality parts. Check valves are also made of the highest quality ensuring that no oil enters your intake track.
Q: Why are catch cans so important on our engines?
A: It's simple really. The stock PCV system is poorly designed. If you've ever removed your intake manifold before, you've probably noticed the dark oily residue left in and around the manifold and its ports. This oily residue also collects on the pistons which can lead to a number of problems including hot spots, pre-ignition, and increased combustion chamber temps.
Our cans eliminate this issues associated with the stock PCV system, and won't break the bank!
Below are some photos of our cans (without the Lashway Logo). We have many colors and finishes to choose from, just PM or call for options!
All PM's returned- to make things easier, all cans are on sale for $109 plus $15 shipping anywhere in the 48...
Add $20 for the FI cans with additional check valves
Color availability subject to change.
Erik
Erik
the smaller ones do fit better, but the larger ones are more effective. i have not tried to fit one yet, we have just started selling these, but i'm sure it could be done.
45 mins from you is still like 4 hours from me... it will come with that type of bracket or is that one a special one?
also are there any pg the gumetal/charcoal colored canisters available now?
I think you may have read that wrong he said he has a guy thats 45 min away from YOU.....
More pics guys...these pics actually are the FI cans with the integral check valves...
Cans are available no matter what FI set up you run...
We also sell breathers that fit into your oil fill hole for $30 plus S&H
That's what I like to hear!
Erik
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
Guys, this is the second time I've had to clean up this thread. Remember that if you don't like the particular vendor, you can always do business elsewhere. Constructive criticism is one thing, but control the bashing, or the ban will get used instead.
Derek
Derek
For all the angry little elves out there, here are some interior shots
Yeah, if you don't like us, our products, or Josh's stunning looks, then pound it!
This is a good view of the interior baffles which help retain the oil deposits.
