Florida Members Fun, sun and LS1's
Rear End Shop
Old 04-24-2012, 11:24 PM
brising's Avatar
Default Rear End Shop
Hey guys I have a 2000 Pontiac Trans Am WS6 with 50,000 miles, been having an issue lately with the rear end whining when accelerating especially more noticeably when over 55 mph. I've taken it to a couple shops and they've change bearings and ring and pinions but havent solved the problem. I've read where if the gear isnt shimmed correctly it will still make the noise. Does anyone know of a good mechanic near the Naples Ft Myers area or relatively close to that? Im running out of options and out of my mind with this noise? Thanks!!
Old 04-24-2012, 11:29 PM
Erik@Lashway's Avatar
Call Moser, then buy one.
Erik@Lashway
Old 04-25-2012, 05:53 AM
NitoV's Avatar
I had the same issue last year. New bearings did most of the trick. It still makes noise but not nearly as much as before.
Old 04-28-2012, 10:44 PM
Swflbt22's Avatar
did the noise change at all after any of the attempted repairs.
Old 04-29-2012, 05:37 PM
brising's Avatar
No..they even put a different rear end in from another 2000... making same noise.. doesnt make sense..
Old 04-29-2012, 05:38 PM
brising's Avatar
Could it be be the rear axle bearings by the brakes transmitting the noise? I just am clueless?
Old 04-29-2012, 05:39 PM
Trevor.j's Avatar
Advance drive line hands down. Or trz both are in central florida
Old 04-29-2012, 05:54 PM
Blackbird-WS6's Avatar
they swap rear ends and still doing the same thing?? you sure its the rear end making the noise??
Old 04-29-2012, 06:10 PM
Steve01SS's Avatar
If they swapped rear ends and the noise is still the same, I would look into the trans. I would not think they both make the same noise.
thats what im thinking
Old 04-29-2012, 08:28 PM
tatertot91's Avatar
Most likely not the rear if the noise stayed the same
Quick Reply: Rear End Shop
