Custom LS1 Head Porting trouble
Custom LS1 Head Porting Question
https://ls1tech.com/forums/showthrea...46#post6151246
I recently purchased heads/cam from a local area guy who got the heads from a company called Precision Motorsports.
After I purchased heads/cam I took them to my engine builder, to go through the heads/check the cam.
Upon inspecting the heads they found that the valves weren't seated correctly (up to 30% difference), they never lapped the valves in correctly and when completing the hand porting work they hit the bottom of a few valve guides, and they removed the vein out.
I am told there is a ledge or something in the intake pocket from the runner that is called a vein, that when the fuel comes in, it hits that, and atomizes, and when they removed that from the porting/polishing, it made the fuel "puddle" and you could see where it ran down inside.
My engine builder is very up on the new engines, but they mainly deal with older engines, so I am lookin for other opinions.
Did the guy who ported the heads messup by removing the vein?
Also can you give me a little more detail as to what it actually does/looks like?
These are the heads/cam purchased from Ryan Seagraves, who got the heads from Precision Motorsports.
"Stage 3 port/polish LS1 Heads ceramic coated, larger ferroa valves"
http://pm-fl.com/catalog/
Moderator
Maybe means the "swirl ramp" which does help low speed
mixing at the expense of airflow. A "Stage 3" job means
all out for airflow and this is a likely victim in the process.
Not abnormal for the claimed type of port job, but not a
great idea for a street car that wants to not be a pig
around town either.
Why you would put coating on / in heads I dunno either.
I guess to cut that last little bit of heat from the air but
I sure would be paranoid about flaked coating going
through the motor if it's in the runners, and if it isn't in
the runners then it's useless other than show.
around town either.
i was also there when teh car dynoed and have personally riden in the car and driven the car. my friend, you are worrying about nothing. put the damn heads on the car and enjoy it. you said your "head porter" knows gen three engines but deals with older engines. which is it? who is it?
why the heads were coated? b/c bob who owns precision motorsports first started out as precision coatings. that was his first business. nothing wrong with coating the heads.
as for taking the swirl vein out, many many head porters do this. it was designed for emissions standards, which we have none in FL. it has nothing to do with fuel puddling. that is a product of the stock tune and the Ltrims fighting the big cam. it happens to every single cammed car on this site. it will not hurt low end velocity. your head porter should know this. the heads made over 400 ft lbs of tq at the rear wheels on an honest dyno on pump gas.
why haven't you put the heads on the car yet? better question, why didnt you just call the head porter with these questions since you have his contact info?
I am in no way complaining about the performance claims or honesty of the person I purchased them from. When I bought the heads I had 1289 dollars in my bank and a 5 dollar bill in my wallet.
With my job I can save maybe 100-120 a week. I need
Timing Chain
Gaskets
Lifters
Pushrods
Injectors
and 375 +dyno time tune by Jeremy.
Again, I am not complaining. My dad thought it would be a good idea to run them by our engine builder just to make sure, because we aren't rich this is my only way of transportation, we don't have a spare vehicle, and I can't have a valve dropping or anything.
I was just gonna have them check the springs and remove the valves, clean up the pockets and reseat the valves.
Than they came to me with all this stuff. I am trying to gather more info, rather than taking one person's word.
and Ryan, I got your PM and my dad called but they were out of the shop all last week, and I emailed him about it, and got his cell phone number yesterday. My dad called him today about them.
As far as I thought, you ordered them and had them installed, I wouldn't of thought you yourself or RevXtreme thoroughly examined them, just put them on, So there may have been some imperfections in the porting, even though they performed that well. Maybe there could of been even more power made.
Timing Chain
Gaskets
Lifters
Pushrods
Injectors
so basically what you are saying is you have no idea what to even look for. go read the internal forums on this site and stop accusing people of selling you heads that have "trouble" as your title states.
what does your budget have anything to do with bob's head porting? learn what to look for, save up and go have fun. like the rest of us. imo you shot without thinking and are taking the words of everyone you can find without forming your own educated opinion. if your engine builder thinks there are problems and you believe him, go ask him why and fix it. simple right? you have asked everyone's opinion under the sun looking for problems. if you dont feel comfortable with a part, dont install it.
again the most rediculous thing about this is you have not once (according to this thread) talked to the very person who ported them. bob is easy to get ahold of. i have not seen bob's work but on a few cars. none made the power of these heads. those heads worked. if you cant make power with them, its your combo that is the problem. you cant argue with 400 ft lbs of tq.
^it has nothing to do with Bob's porting, I was answering your question about why they haven't been installed yet. Everyone told me what a great deal these were, and I wanted to grab them before anyone else. I had planned to just have them in my house till I got all the rest of the parts.
I am not even accusing anyone of anything, I am asking to be more well informed, I didnt even mention anyones name.
I am confused, the heads and cam package made unreak numbers for a stock CI ls1 , what could be wrong with them? I remember they came with nice springs and what not too?
I see absolutely nothing wrong with asking questions.. you like i was a few years back.. are spending every dollar you make on mods for your car.. and thats difficult and you don't want to be taken..
How ever.. do your self a favor.. and ask the guy who ported them about a certain few things you have questions about.. if your still uneasy.. take pictures.. and post them up in the internal engine section.. you'll have knowledgable people and sponsors there to help you out.. the FLorida forum is more of a communication forum..
what it comes down to is you need to be 100% confident in what you bought.. if they made power great they made power.. but i agree there could be more there.. who knows.. every car is different..
I personally see no problem with asking questions.. your here to learn.. and if your anything like me you'll learn to trust no one and do most things yourself.. ask your questions just try the right forum and before you know it you'll be out there making the horsa powa
Mike
Mike
nothing wrong with asking questions. i was just trying to direct him to the correct sources. ie the head porter. he also later posted a link to the tech forums which is a good idea to get other's opinions. but again, nothing is as good as the guy who built them. the questions you have have everything to do with your confidence and the specs of bob's porting. if you feel (or your engine builder) have issues with the valve sealing, then go to the builder. ask him if what is there is correct. ask him why he took out the swirl vein. you might be surprised as there are experts and then there are "experts" lol
sounds like your engine builder wants to make some extra money. Lapping the valves is easy and if you do it yourself it will cost no more then 10 dollars. I would throw them on the car if I were you. Their are alot of smart people in here posting so I would take that into consideration over 1 man who says different.....FWIW
Originally Posted by yomama
if done properly you can go forty thousandths on a stock seat. Boltem on and hang on.
