Norris Motorpsorts Installed and Tuned Cam & Dual Spring Packages $1795
Hey All,
Things are going very well at the new shop and in appreciation I am putting together some packages for folks.
The first is this $1795 Installed and Tuned Cam & Dual Spring Package for F-Bodies and GTO's that includes:
Choice of Comp Cam, either shelf or custom.
Dual spring kit with titanium retainers, seats and seals.
Moly pushrods.
NGK TR55 or TR6 spark plugs.
160* thermostat.
GM front cover gasket.
GM water pump gaskets.
GM front seal.
GM crank bolt.
GM valve cover gaskets.
Base dyno run.
Professional install.
Complete chassis dyno tune with AF and printout.
C5/C6 Vettes are an extra $100.
This normally retails for roughly $2200. We can grind a cam that you want spec wise or can go over the package you are looking for and come to a combination that will work for you. There are several Comp shelf grinds that work very well as well as some customs that we have used in the past.
Please feel free to PM me, e-mail me at thevettedr@aol.com or call me during the day at 407-616-2518. Thanks and best to everyone.
Mike Norris
Moly pushrods.
160* thermostat.
GM front seal.
GM crank bolt.
Base dyno run.
Mike Norris
