Florida Members Fun, sun and LS1's
Thumping under the floorboards?
Old 09-02-2008, 12:30 AM
96tealTA's Avatar
Default Thumping under the floorboards?
When I launch, or if I floor it and the trans. downshifts to first, I get a weird thumping noise from the floorboards. Is it time for a new trans. mount or what? Oh, and it didn't do that before I had longtubes.
Old 09-02-2008, 12:50 AM
torquejunky's Avatar
its the headers/Y, it might be time to massage the floor pan, I'd try playing with the y-pipe first though
Old 09-02-2008, 08:19 AM
slowmofo's Avatar
yep, its your y-pipe hitting your floorpan.. It was a big problem in my 94 till I used a BFH mod..
Old 09-02-2008, 09:08 AM
THE CHOP SHOP's Avatar
Could very well be the y pipe. I would take a look at your trans mount though. Mine was shot at 60k. Pretty much ripped in half and barely hanging together. I got a energy suspension poly mount from autozone cause they had it on the shelf.
Old 09-02-2008, 09:24 AM
10 & 11 Second Club
Caveman's Avatar
Losen the the clamps on the Ypipe +header and use a 3' pry bar to get a gap between the ypipe and floor board then retighten header and ypipe clamps.
Old 09-02-2008, 09:25 AM
fenix999's Avatar
either y-pipe is hitting or your trans mount is fubarred, or both.
good luck
Old 09-02-2008, 10:24 AM
Restricted User
crazykid's Avatar
Transmission mount
Old 09-02-2008, 06:36 PM
bboyferal's Avatar
What happens if you push up on the tranny... Is it loose?
Try that?
Old 09-02-2008, 08:32 PM
96tealTA's Avatar
Just bought a tranny mount. So I'll try that first, and I'll let you guys know.
Old 09-02-2008, 08:44 PM
Restricted User
crazykid's Avatar
You can generally see if the mount is broke or not, you will see rips and cracks in the rubber. 9 times out of 10 floor board thumping is caused by the mount. Let us know if it fixes it.
Kyle
Old 09-02-2008, 09:06 PM
gator's 99TA's Avatar
Kyle
listen to this guy. Kyle is the ONLY guy that is allowed to work on my car.
Old 09-03-2008, 08:13 AM
bboyferal's Avatar
My motor agrees!
Old 09-03-2008, 08:27 AM
slowmofo's Avatar
yeah but it didn't start till he put the long tubes on, and the tranny mount is more of a banging in the tunnel, not the floor board..
Good luck OP let us know what you find..
Old 09-03-2008, 09:05 AM
SSJIMMY's Avatar
I will have to look at my tranny i have had the banging for a while now and just figured it was my y-pipe. how much is the mount not to much I would guess.
Old 09-03-2008, 09:13 AM
Eroc's Avatar
Trans Mount... Y-pipe would be one Thump at hard launch...
Tq Arm is kitting the Floor Pan I bet...
Trans Mount is none existant anymore...
You need to fix this ASAP...
Change in launch Angles can/will damage drive line and rear end.. also undo wear...
had this issue with my 89 ROC...
Old 09-03-2008, 09:29 AM
slowmofo's Avatar
poly mount is only like 20 bucks
Quick Reply: Thumping under the floorboards?
