Which Roller Rockers to use with Boost?
I have a stroker with a DISC and am thinking on upgrading the rockers. Which is the ones everyone prefers. I just want to have some more insurance.
I just took off a set of YT ultralights and put the stockers back on, most definately had a little valve float above 7000rpm. Thats with the 8019 AFR springs and an XE lobe .600 lift cam @ 17psi.
Some claim that the stockers are tough on valve guides so it depends on mileage I suppose, The YTs are nice rockers, but I dont put many miles on so valve float is a bigger issue than valve guide life for me.
So are you saying just leave the stockers on. It is not a dailer driver and the cam is a blower specific cam I see alot of people on here using. I believe the RPM limit is set @ 6400.
Thanks
DG
Thanks
DG
Its up to you, at 6400rpm I doubt you will have any valve float issues, it then turns into a reliability thing with the guide wear. Either way it isnt huge money for aftermarket rockers and at least you pick up a few HP plus not having to worry about the stock rockers falling apart.
