Which heads for 408
Old 10-18-2008, 08:47 PM
mr_biscuitz's Avatar
Default Which heads for 408
408w/f1a blower, I know lots of guys use the 6.0 heads so I want to know if I should go 6.0 or go with a ls6 head. The cr is going to be either 9.1 or 9.5.1
Thanks for your help
Old 10-18-2008, 08:50 PM
98Z28MASS's Avatar
Hmm with a 408 and an F1a id say look into a thicker deck head like the afr 225s or maybe a pair of TFS heads. What are the power goals for your setup? 6.0 (317) heads will work but might not be the best for your setup.
Old 10-19-2008, 07:38 AM
Navy David SS's Avatar
Very please with my AFR 225's. You do want a "thicker" head to hold the boost.
David
Old 10-19-2008, 07:40 AM
Race your car!
JL ws-6's Avatar
ET's with a big chamber, if you can get them. If not, TFS would be choice #2.
Old 10-19-2008, 08:05 AM
venom ws7's Avatar
AFR / TFS / ET do go with anything else like Navy David Mentioed thicker heads for boost.
Old 10-19-2008, 08:08 AM
52172's Avatar
Vengeance has the TF cast heads set up with dual springs out the door for 1650 can't go wrong. Plus they flow over 305 cfm @ .600.
Old 10-19-2008, 12:41 PM
Gordon0652's Avatar
ET heads!
Quick Reply: Which heads for 408
