need some opinions
need some opinions
Hey guys,
I have a car that is not making the power it should. I believe that my turbos are to small for my large cube motor and choking the motor.
The setup is a 403 with Dart 225 StgIII ported and coated heads with t3/t4 hybrids. I am embarassed of the numbers, so I won't post them but let's just say that I haven't reached 700RWHP yet. That is what I want to fix.
I need you thoughts/opinions to help steer me in the right direction.
1st idea: Convert to t4 flange and v-band the downpipe. Now the downpipe is 2.5 in, but should be ok with me running twins. Also, the car is a street car with very limited track use. I think the t4 flange will help flow and relieve some of the back pressure, but I am limited on size. The size of the turbo has to be physically the same size of a GT35 to fit.
I have someone lined up for the job (he just doesn't know it yet ). So, looking at the cost analysis, I would have to consider fabrication to t4/v-band, keeping the turbo in the same location, and buying new turbos.
2nd idea: To keep everything as it is and just buy some GT35r's. GT35r's are around $1200/piece (or maybe someone can help me out there as well )
My goal for the car is to make the most power at a lower boost setting. I don't see any reason why the car can't get to 700RWHP on 10psi.
Gingervitis Addict
Man you guys are harsh.....TTT for my friend....
Basically He's asking this....He has 2 options:
Change out his current turbos (some small t3/t4 hybrids with HUGE backpressure I'm sure)
OR
Do some modification to his current setup to fit either some MPT70s or TC series turbos.
I figure either way will probably end up costing about the same. Opinions?
OR
