haveyou ever over tightened a procharger belt?
belt came off on the high way last night my buddy put another one on today... got some smoke then new blower belt snapped!! the idler pulley is frozen and the bearings in it are shot!!! this kit only has 2000 miles on it.. i was told to crank the tensioner pretty damn good so its tight like a guitar string but was it too tight and caused the bearings to seize in the idler pulley on the tensioner?? mods are d1sc 10lbs 6rib 7" crank 3.85blower pulley....how tight is tight? cause i dont want this bull sh** to happen again... input??
We've run the 6 rib kit belt tension really tight and have not had the idler pulley bearings fail on us. Take the pulley to your local Napa, they should be able to give you bearings for it. The bearing part number is floating around on here some place, you should be able to find it with a search. Bob
