428ci LSX iron block...single turbo.....A/C.....????
Old 10-27-2008, 01:20 PM
spoolit's Avatar
Default 428ci LSX iron block...single turbo.....A/C.....????
I've seen a couple threads lately on 428ci's and single turbo's......thats what we were thinking of doing, so I thought I'd ask some questions.
Looks like OFI and "Kentucky Turbo and Performance" is our only choices for the kit.
We have an LSX iron block that has been checked out and its perfect, thank heaven.
We chose to use a sheet metal intake (Hogan most likely) with ETP 6 bolt LS1cathedral port heads.
For our power goals we chose a 98mm turbo.
Is 428ci (4.125" bore x 4" stroke) too many cubes for that turbo?
Will there be lag with 428ci through a 4L80E tranny with a 3200 stall and 3.23gears?
What cubic inch would be better than 428ci….if 428ci isn't good?
Me and my son are building it for no other reason than to roll race. Not drag racing, rolling runs only. It will also be show car ready. It must be a single turbo set-up as its going into a 2001 WS6 F-Body T/A. A/C is a must to keep. We like the OFI kit but don't know if it will fit a 98mm model turbo, maybe the FI98X, might have to re-fab that kit or another kit but we’ll do what’s needed to make it fit. Car is mini-tubbed, lowered and has a very nice suspension (LG Motorsports panhard, SFC, LCA's, G2 springs, Hotchkis STB, Hals all around) already as well as big Willwood brakes. Strange 12 bolt rear end. Tranny is a brand new fully built 4L80E not installed yet. Engine is all we need. I was thinking a Cola crank, Manley rods and Diamond pistons.
Do we know a lot about turbo powered cars....not really. But everyone we know has them so we have a lot of exposure. Just not with LSx engines. We've just had 400-500 RWHP N/A cars mainly. Couple that had nice nitrous shots that were pretty fast. We're ready for the big jump.
Thanks for any input. Build starts immediately after x-mas. Just need to figure out the turbo kit.
Trey
Old 10-27-2008, 02:58 PM
digitalsolo's Avatar
Do some reading on OFI...
It would appear that KYTP is your only bet.
Old 10-27-2008, 07:39 PM
spoolit's Avatar
Damn, just read some of that stuff about OFI.
Can KYTP make a custom kit with A/C?
Old 10-28-2008, 08:11 AM
I'd get ahold of them (they're on the board and easy to reach), but I'm sure they can do so, they do quite a bit of custom work.
Old 10-28-2008, 11:02 AM
NA$TY-TA's Avatar
Have you already ordered the heads??
The reason i ask is they have been taking forever to get... like 6-12 months......
Id go with a smaller cubed setup at first also. give ou room to rebuild if something does happen down the road. more cyl wall left.
A 98 mm would be fun with a 402/408..... i see two ther things you didnt mention that if not budgeted can really sneak up on ya... about $5-6K worth...
1. Fuel system.
What Pump, what FP Reg, What size lines, what injectors, fittings.... east $2500 if ya dont watch out LOL
2. Tuning.... with what?? Stock PCM, BS3???
Kyle
Old 10-28-2008, 11:16 AM
Originally Posted by NA$TY-TA
1. Fuel system.
Quoted for truth.
I'm doing a "basic" fuel system, (dual walbro in tank pumps), -10 AN feed and -6 return with aftermarket rails and a Mallory boost referenced regulator and I'm in a solid 1500-1600 dollars with fittings, pumps, filters, etc. You'll need more than I have as well.
Although, judging by your engine choice, I'd say you have substantial budget for the build.
Old 10-28-2008, 11:38 AM
NA$TY-TA's Avatar
Originally Posted by digitalsolo
Quoted for truth.
Yep... "" I know from experience dude"" uhh uhhh...LOL
Old 10-28-2008, 12:12 PM
no title here
skyhighsami's Avatar
I was thinking of doing a similar build with my 98 Camaro only with a 408. I have been doing some reading that the C6 manifolds will allow you to keep the AC. I will be getting some this week and hopefully have the ball rolling around the same time frame you are talking. I would look into that.
Old 10-28-2008, 01:24 PM
7 Second Club
Phil99vette's Avatar
I'd do an aeromotive belt drive before dual walbros any day.
Old 10-28-2008, 02:11 PM
Gingervitis Addict
slow67's Avatar
X2 me too....no amps and no noise.
Old 10-28-2008, 02:58 PM
spoolit's Avatar
Local guy in town has a set of the ETP LS1 cathedrals. They were going to use it on their 430ci LSX iron blocked, big single turbo build for some Grand National drag car, but they are selling them to me.
Wouldn't a 4.125 bore on the LSX iron block leave a ton of cylinder wall left?
If we use the FI98X, wouldn't a 408ci be too small to to get the max potential power from it?
Is it a mistake to go 428ci? We want 1450 rwhp, thats the firm goal.
How about a compromise, 422ci. (4.0 stroke x 4.1 bore)
1. Fuel system.
Aeromotive or maybe the Nasty Perf. fuel systems. (what esle is there?) BS3 for sure with a SD tune. 100% full time race gas. All of those other details you brought up I'll leave to the turbo guru that builds the kit. I looked into a Gayle Banks 427ci TT over a year ago, but $55,000 is just way too much for just an engine and turbo kit. I know it can be done cheaper with the same quality.
But I will spend the cash for this build, no skimping anywhere.
Old 10-28-2008, 07:47 PM
BlownVette 2001's Avatar
Hinson MotorSports has a single log style set-up for the C5's that may work with your application and would allow you to keep your A/C.
Old 10-28-2008, 08:38 PM
spoolit's Avatar
F-Body.
Old 10-29-2008, 04:21 AM
F-Body.
I know that it's an "F" body, but this kit mounts the turbo up where a procharger (Centrifigal) would mount.
Old 10-29-2008, 08:27 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I agree with that. From my experience doing the belt drive would have been easier, cheaper, and more effective than my current setup. I am happy with with it as it will support the power I am going to make, but it is not the best solution.
Old 10-29-2008, 08:29 AM
LS1TECH Sponsor
DrTurbo's Avatar
408ci engine would be perfect for it.
Old 10-29-2008, 01:00 PM
spoolit's Avatar
When you say 408ci is "perfect", is that for fast spool-up time and potential power we will make?
Spooling fast is the priority.
I assume the difference in final power/torque numbers between a 408ci and a 422/428ci is minimal, so if I had the choice I'd rather have the bigger cube engine for quicker spooling.
Am I thinking correctly, or no?
Old 10-29-2008, 01:45 PM
Elcaballoloco's Avatar
1450 RWHP and just for skreet racing? Have you considered how you're going to hook all this power?
Old 10-29-2008, 01:47 PM
LS1TECH Sponsor
DrTurbo's Avatar
For the application that you are doing, a 94mm would be faster spooling and enough to get you killed. A 408 will spool either turbo very quickly.
LS1TECH Sponsor
DrTurbo's Avatar
Street racing???? I thought this was a track car?
Quick Reply: 428ci LSX iron block...single turbo.....A/C.....????
