for those of you that ever run into a Procharger leak
Old 10-29-2008, 11:59 PM
Mr.Big's Avatar
Default for those of you that ever run into a Procharger leak
Procharger refuses to sell any parts, so here's what I found for my P1SC headunit rebuild...
http://www.superchargerrebuild.com/?page_id=53
I need the shaft seals that they will not sell, and the wanted several hundred dollars to replace... + who knows how long to do it...
($65) through these guys www.superchargerrebuild.com ... see the bottom of the page in the first link...
Hope this helps someone in the future, the procharger seals have no part numbers on them, and no way to source them...
www.superchargerrebuild.com sells all seals, and bearings, including ABEC-9 rated Ceramic bearings for replacement... The stock bearings have "China" stamped on the side, and are only rated at 45k, the ABEC 9's are rated at 65k...
Old 10-30-2008, 07:28 AM
lionelc-5's Avatar
Default Thanks
Thanks for taking the time to post this information up. It could be very useful for alot of people.
LionelC
Old 10-30-2008, 08:17 AM
DanWS6's Avatar
Awesome, thank you.
Old 10-30-2008, 11:39 PM
Mr.Big's Avatar
LionelC
Originally Posted by DanWS6
Awesome, thank you.
You got it guys!!!
Old 04-17-2009, 06:22 PM
BlkHwk's Avatar
Good Info, thanks for posting.
Old 04-17-2009, 10:31 PM
helicoil's Avatar
Hey good piece of info!
Old 04-17-2009, 10:56 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Their prices aren't that bad either. Those are definetly good links to save.
Random... Mr.Big what bottom end do you have in your vette that made those numbers?
Old 04-18-2009, 07:38 PM
Moderator
BADZ's Avatar
Good info Mr. Big...
Old 04-18-2009, 08:07 PM
Awake455's Avatar
Wait...that doesn't make sense. From what I have found ProCharger has always used abec 9 spindle bearings. If they were using bearings that only were good to 45k they wouldn't have any head units left in 1 piece. The P1SC's redline is rated at what, 62k?
Could've sworn the front seal had a part number on it, that should be easy to buy at a local parts store if you wish.
Quick Reply: for those of you that ever run into a Procharger leak
