Got a TH400 with brake....how to launch?
Old 10-30-2008, 10:51 PM
TS6
TS6's Avatar
Default Got a TH400 with brake....how to launch?
I'm new to the transbrake thing, so how do I launch this thing? Just stand on it or am I looking to leave at a certain RPM? Would a 2 step be super beneficial to me? Is it harder on the motor to use a 2 step? It sure sounds violent, but cool as hell too.
Old 10-30-2008, 11:03 PM
Zombie's Avatar
1. put trans in 1st gear and press trans brake button
2. floor car, release trans brake at desired boost/rpm
3. ???
4. PROFIT!!
if you street drive it's wise to put the button on a switch to prevent accidental activation. Don't ever touch the button wile you are moving.
Old 10-30-2008, 11:09 PM
TS6
TS6's Avatar
3. ???
4. PROFIT!!
I know that much, but thanks.
I guess what I'm wondering is if I should use a 2 step or if just bringing it up on the convertor is enough? Like I have a 4000 stall: Do I want to just stand on it, reving to 4000-ish, and launch? Or do I still need the "flash" of the convertor to get things going? Say if I use a 2 step at 2500 RPM, I stand on it, motor sits at 2500, release and it launched and flashes the convertor to lets say 5000-ish.
Hope that made sense.
TS6
TS6's Avatar
Oh, and all my stuff is on switches, just in case. LL, TB, exhaust cutout, etc.
Old 10-30-2008, 11:17 PM
kp
kp's Avatar
Use a two step, start at 2500rpm and work your way up. WOT on the brake will most likely slow the car down.
Old 10-30-2008, 11:19 PM
TS6
TS6's Avatar
Is the LPE 2 step still the recommended unit?
Old 10-30-2008, 11:21 PM
kp
kp's Avatar
any 2 step that works in the recommended unit
Old 10-30-2008, 11:22 PM
TS6
TS6's Avatar
Can I just have yours?
j/k
Old 10-30-2008, 11:34 PM
kp
kp's Avatar
Mine was in the BS3
But the LPE looks simple enough..
Old 10-31-2008, 12:01 AM
sidewayz28's Avatar
3. ???
4. PROFIT!!
Underpants gnomes???
Old 10-31-2008, 01:30 AM
ninetres's Avatar
Whys that?
Old 10-31-2008, 02:29 AM
Black X's Avatar
Mine was in the BS3
I have the LPE unit. Awesome value for the dollar
Old 10-31-2008, 05:27 AM
tomz28's Avatar
i have a LPE very easy by the looks of it. but have not hooked it up yet cant wait
Old 10-31-2008, 09:13 AM
kp
kp's Avatar
Originally Posted by ninetres
Whys that?
With a blower the boost is instant and if you have the right converter you will push right past the max torque of the engine and lose the advantage of the torque multiplication. Every converter/combination is different, just takes some experimenting.
Old 10-31-2008, 10:26 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
4000 rpms is nothing for that combo Sam, just run it like that and get a 2 step to mess with for later. You are heavier and don't make as much power as kevin did so based on your mph of 139 best you can leave at 4000 and hopefully hit 9.8@142 or something like that.
Old 10-31-2008, 11:02 AM
Zombie's Avatar
Trans brake gnomes
Old 10-31-2008, 12:10 PM
sidewayz28's Avatar
Trans brake gnomes
haha very funny episode
Old 10-31-2008, 12:13 PM
CamaroKidZ28's Avatar
3. ???
4. PROFIT!!
i found a /b/tard
Old 10-31-2008, 12:16 PM
Moderator
FANTAZ28's Avatar
I use the transbreak just pulling out of my driveway!
Old 10-31-2008, 12:35 PM
tirefryin_s10's Avatar
I as well may have been known to do some trans brake launches in the mcdonalds drive through.
Quick Reply: Got a TH400 with brake....how to launch?
