2048.9 hp/1507.1 lbsTq 400ci LSX
I just came across this amazing built on Hot Rod Nov 08,you guys gotta check it out.
2048.9hp/1507.1lbs Tq @7140 RPM
specification:
400ci LSX Tall deck
callies crank 3.75 inc
GRP 6.125 inc
Diamond pistons 57cc, CH 1.403
Comp 254/257 0.775/0.776 114
prototype cylinder heads from GM 44cc
Twin Accel 2,100-cfm throttle bodies
custom tunnel ram-type intake manifold
pair of 88mm Precision turbochargers With Air/Water IC
front-mounted distributor with an Accel distributor and Mallory coil
Accel/DFI management system
Moroso 5 stage Dry-sump sys
specification:
400ci LSX Tall deck
GRP 6.125 inc
Impressive build and love the intake. Really doesn't make any power until about 7000rpm on engine dyno. Put it under a load and i expect you will see that power band move a little more to the left.
Been around for a while and nothing new..... a few people on here make that much HP.
Its on an engine dyno so your talking 1700hp or so..... look at Major, Kempt, Phil, Wormboy, Both Ohio Boys....
How much HP do u thing it taked to run 200mph or close to in the 1/4
Race car yes.... street car no.
