How much boost will a stock 6.0 handle?
Old 11-03-2008, 07:14 PM
4SFEDSS's Avatar
Default How much boost will a stock 6.0 handle?
how much boost will a stock 6.0 lq4 handle? im going to be putting a basically brand new lq4 into my third gen. Its going to be a stock 6.0 with a turbo cam and upgraded rod bolts. And of course all supporting fuel mods. I was planning to make about 10 lbs of boost with a single t76 turbo and expect at least 550rwhp. Does that sound realistic?
Old 11-03-2008, 07:19 PM
Silver_TransAm's Avatar
10psi is going to be the limit safely. I am running a 76mm at 10psi now and making about 600hp on an 5.7 ls1. You should reach 550 no problem. Just get a good tune.
Old 11-03-2008, 07:20 PM
omore001's Avatar
Yes that does sound realistic. Stock LQ4 can handle 9 lbs through an intercooler and probably 12 lbs with meth injection, safety is all in the tune.
Old 11-03-2008, 10:27 PM
67Firebird455's Avatar
I'd tune for 10 to be honest. The LQ4 is lower compression than a stock LS1, so I think it'd be fair to get a couple PSI more out of it without blowing it up. Meth injection is your friend, along with a good intercooler. You'd be able to run more than 10 with meth, but that's up to you if you'd like to depend on it.
Old 11-04-2008, 06:54 AM
Frank02L's Avatar
We made 20psi before it started hurting itself. Bent one set of rods and broke the second. Make no mistake, VP Q16 fuel only run in it. It went 5.72@126 in the 1/8th at 3280-90lbs
Old 11-04-2008, 08:09 AM
87silverbullet's Avatar
There was a video of a GTO on the dyno with a stock 6.0 with a z06 cam that made 825rwhp on 19lbs of boost,but I don't know how long it lasted.
Old 11-04-2008, 09:44 AM
Grr
Grr's Avatar
I was running 10-12psi on mine with no intercooler on 89 octane for 2 years, and its still going. I put in rod bolts the 2nd year, was making around 550whp with this setup.
I put some 93 octane and a spash of c16 in it once and had it up to 16psi, still no intercooler. I figured by the races i won it should have been in the high 600whp area, no problems just keep the timing down.
Old 11-04-2008, 09:48 AM
LS1Tech Sponsor
hellbents10's Avatar
Still running strong!!! up to 20+psi now, race fuel and meth only.
Old 11-04-2008, 01:02 PM
All I can say is DAMMMMNNN! You must be running a very conservative tune on there to keep it alive. Way to go to show how strong these motors really are. I wouldn't have the nuts to run the boost up that high
Old 11-04-2008, 01:13 PM
GT67METHV's Avatar
i had the same nagging issue...
do you want turn key reliability,
or sitting on the edge of no mans land?
start at 5-6lbs and dont concern yourself with the dyno
numbers untill you build confidence...then build boost.
not to say a bad tune cant pop your motor at 5-6 of boost.
start conservitive, you wont regret going the slow road
untill you understand tuning and boost and all that implies.
good luck...be smart!
Old 11-04-2008, 06:15 PM
4SFEDSS's Avatar
I'll be with the tuner when he tunes it so i'll just turn the boost up as we go. Its not my dd but i dont want problems.. Thanks for all your input guys, i cant wait to get started on this.
Old 11-04-2008, 07:54 PM
4SFEDSS's Avatar
Im debating on whether or not i should do a cam. regardless if i do or not i will be putting in some good springs and pushrods. Am i going to gain that much by doing a cam, i know that it isnt really nesescary with FI but i figured i'd do it since the engine's on the stand.
Old 11-04-2008, 08:22 PM
Josh@PremierAutosports's Avatar
Yes install a nice turbo cam.
Old 11-04-2008, 08:30 PM
BetMinesFaster's Avatar
There is plenty to gain by a good turbo profiled cam, and look at it this way......LQ4's are cheap, so if ya shell 1 or 2 testing the limits its still cheaper than building 1 Buick Turbo 3.8
Old 11-04-2008, 08:41 PM
Frank02L's Avatar
Heck we have a good sized cam not-turbo spec'd and it seems to run. ok.
Old 11-04-2008, 11:06 PM
87MONTECARLOLSXON6'S's Avatar
Very good tune is a must!!!! Safe at 10 p.s.i, stock bottom with Arp's, 12-14p.s.i with meth, well for me!!!
Old 11-06-2008, 07:27 PM
4SFEDSS's Avatar
This might sound stupid but can the intake/charge side of the turbo be clocked to better fit my application?
Old 11-06-2008, 10:19 PM
Frank02L's Avatar
yes, just make sure the oil feed stays up and drain stays down...
Old 11-07-2008, 01:40 AM
js2fst's Avatar
So you can make more rwhp with a stock 6.0 than a stock Ls1?
Old 11-07-2008, 10:12 AM
Frank02L's Avatar
I would think so because you have a little bit more cubic inches. Then something alot of people over look when the bore size is increased is the reduction of the valve shrouding.
Quick Reply: How much boost will a stock 6.0 handle?
