Anyone have pictures of PT-88 Turbo?
Hey guys,
I just ordered a PT-88 and haven't found many pictures on the web of them. I know the turbine housing is bigger then my T76 and the unit is about 1" longer as well which shouldn't be too much problem to work with on fitment but I sure would like some good detailed pictures or even some comparisons of the two (T76 Vs. PT-88). If you have some and have a second to post them I sure would appreciate it!!
Thanks Guys!
Chris
Thanks Guys!
Chris
Hey guys,
Thanks Guys!
Chris
Thanks Guys!
Chris
This is a 76gts next to a t4 88mm.
Hey guys thanks so much! I appreciate you taking the time to go out of your way to help me out on that!
that sucker has a onsterous CHRA section huh! I am guessing I will be fabbing up a oil drain fitting which doesn't look that bad to do, but how about the turbo oil inlet.. is it threaded where I can put a -4AN 90* Fitting in it for my existing oil lines or is it flanged only?
Thanks again!
Chris
Thanks again!
Chris
I don't know what a large frame turbo oil drain looks like..lol I have been running T76, PT74GTS, GT4088R, 16G GT3582R's.... soooo.. is it the same as the T76?
Chris
Chris
