Turbo feed/drain question
Old 11-11-2008, 09:47 AM
98Camarod's Avatar
Default Turbo feed/drain question
Which one is which on the turbo? One has a circular port and one has a larger rectangular port. I'm assuming that the circular is the feed and the rectangular one is the drain. Not sure on that. Having said that, I also am in the need of the adapters for the feed and drain. I have a -10 drain line, but the supplied part is too large for the turbo. Also for the drain, the supplied part is not threaded on the turbo so I need the adapter. Both of them have two threaded parts and then the feed/drain part. It is a garrett gt70
Old 11-11-2008, 11:26 AM
thumpstick's Avatar
yes, the small circular one is the feed and the larger rectangular one is the drain. As for the other stuff... there are a lot of companies who sell the various flanges and adapters you might need. I'm sure someone else will chime in with where you can get them.
good luck,
-John
mike13's Avatar
try ATP turbo, check their website, nice people, fast shipping.
Old 11-12-2008, 04:20 PM
98Camarod's Avatar
Thanks, I figured the rectangular port was for the drain. Still looking for them though.
