cross over length? is it important?
getting ready to start ona turbo project but because of whee i want the turbo and the packaging restraints the one side will be a lot longer then the other....is that a problem? also a particular length before lag becomes an issue? if so i will have to rethink where to put the turbo i guess.
When you see rear mount turbo cars running 9s I don't think you have anything to worry about if I understand your concern properly
Good luck.
Good luck.
Dont worry about it. Equal length tubes may benifit you if you were building an all out race car or something along those lines. Look at pics of 90% of the turbo cars out ther making more power than any one person needs. Most of them have the turbo mounted and run what ever pipe is need to get to the turbo.
