Question on spring loaded tensioners
Old 11-19-2008, 10:22 PM
Jimmy P's Avatar
Default Question on spring loaded tensioners
I have a SDCE tensioner setup on my car, and I believe I am the third owner of it. It has been in my car for a few years... Is there a way that I can test the tensioner to see if it is properly working? It does give tension, but I am not sure if its enough. Do spring loaded tensioners progressivly give out less and less tension with time? Or will they either work, or not work? Thanks
Old 11-20-2008, 09:24 AM
conan's Avatar
How old is the belt? Did you get the little tool from sdce to adjust the tension? I have noticed my sdce tensioner needs to have a little adjustment as the belt gets older. All of the experience I have with spring tensioners has been they work or the spring gets seized and you cant even move it at all.
Quick Reply: Question on spring loaded tensioners
