recommend lobes for fi cam?
Need to pick something to work with my new combo:
Forged 346 9.2 compression
15 psi supercharged
6 spd
Criteria: Make great all around power with good drivabilty and some lope at idle. I'm thinking something along the lines of a 224/232 .581/.588 115
Your thoughts?
15 psi supercharged
6 spd
Your thoughts?
Okay I did a search and it seems everyone is using XER lobes. I also found out that Speed Inc has the above cam I described listed as a blower cam. It's basically the same as the comps blower cam but slightly more exhaust duration and lift. How do measure the overlap of the cam?
http://www.exoticperformanceplus.com....html?item=679
Check out our blower camshaft in the above ink.
There are sound clips of it in the links below. Bob
http://www.exoticperformanceplus.com...html?item=1109
http://www.youtube.com/watch?v=1pSpYYylt7c
