Mud bogger 4x4 turbo?
My in-law, and his friend are going to put together a turbo truck for the mud boggs but on a budget.
Since I know how to use the internet best, I wanted to get some ideas on this. I think where going to use an ls base motor, but they want to keep the bottom end stock. How much horse is possible on an ls1 or a 5.3, with a stock bottom end.
Is it easier to switch to carb or stay fuel injected. Can anyone tell me some common mistakes people forget to think about. It's going to go into a c/k series truck. Overall a mudd bog run is only about 200ft or more im not quite sure, but it will be wide open the whole time. They want to get 800fwhp out of it an 8-10psi boost, but from what i understand boost is a measure of air before it gets into the intake? So you can really make a **** load of boost an it really doesn't mean anything?
Thanxs for any help
Thanxs for any help
Thanxs for any help
Thanxs for any help
No stock bottom end lsx engine is going to hold together at 800 hp for any extended period of time. If your going to use a stock bottom end engine id say go ls2 or lq4 6.0 liter. The lq4 truck block also comes with the 317 heads that are good for boost. Should be able to hit over 500 whp with 8-10 psi. If you want 800 hp on 10 psi then your going to need a massive cubed engine.
a couple of things to think about. Is the truck straight axle front end or IFS? The half-shafts will stand NO chance against that much power. You're going to need a stout drivetrain. Also, thiink about the placement of the turbo...get it wrong and you're sucking water/mud into everything.
its a straight axle truck they can build mudd bogging trucks no doubt. It just the first venture into turbo territory, and already know any input i put in won't do much cause my in-law caN BE VERY STUBBORN. So close to hitting his friend who use to be a teacher, who simply in the nicest way possible said i was dumb, i was about to say thank god i never had you, hoping he would say why, I'd of responded cause i would of popped you in the face
suspect at 800fwhp. I believe the LQ9 has the strongest stock rods.
LQ4 would be a little better for boost with its lower compression though.
A 6.0L truck engine with a Z06 cam swap and about 12-15psi
should hit your wanted power levels of 650rwhp.
True, ive seen a few builds that have pushed the limits of the stock short block, but seriously without the perfect tune, tons of fuel, and enough octane a majority of the time a stock shortblock is going to last long past 600rwhp nevermind 800 rwhp. The ones who have are well experienced and kudos to them but unless they are having it built by a pro I wouldnt use a few outliers whom have had a stock shortblock survive at those levels be representative of what a stock shortblock can handle.
I hear ya, id do the same too if it were just a toy. Just depends on how reliable they want the truck to be. Still though its pretty amazing seeing people push the stock lq9's to those power levels and have them survive for a sufficient amount of time, shows what a great builder and tuner can do.
