What torque for the 2 middle head studs on a warhawk block? how much is the stud off?
On the warhawk engine block how much do you torque the head studs to? Most important what is the torque for the added studs ?
All 5 heads studs are in the same spot as the iron lsx block but the intake side middle head stud right?
Where is that middle stud compare to the lsx block ? Just moved 1/4 (?) of a inch to the center of the block but still in line with the lsx pattern?
Can some one lay a LSX head gasket over a Warhawk head gasket and post a pic so i would be able to see
I had mine torqed to 75ftlbs - same as the other 4 studs.
You should be torquing your heads to the same amount as your machinist did when he torque plate honed your bores.
